Where to buy H / I Beams?
   / Where to buy H / I Beams? #1
TWD
Gold Member
Sierra Nevada Mountains - CA
Kubota M59
Looking to build a wood splitter and want to do it right, and extra beefy.
Looking at acquiring some: w8 x 48 or w10 x 54
Going to pair with a 5x30 cylinder, 28GPM pump, etc...
Is everyone buying at scrapyard? Places I'm finding are $500+ for that beam :(
   / Where to buy H / I Beams? #2
If you have a county bridge department, you might check with them. I was able to get a 5' used H beam that way when I built mine: HPIM3027.JPG
   / Where to buy H / I Beams? #3
My local metal recycler resells metal. Some do, some don't. But used steel is dirt cheap.
   / Where to buy H / I Beams? #4
I got mine at a local steel fab shop that a friend used to work for.
If I had sourced it from my steel supplier it would have been more than 4x what I actually paid ($50)
   / Where to buy H / I Beams? #5
W8 and W10 are not the most common materials so finding them may take a bit of searching. I agree that a local fab shop would be best if you can find what you need.
   / Where to buy H / I Beams? #6
I found some on craigslist... cheap.
The local metal guy has acres of inventory he buys for scrap... but he gets top dollar for what he sells retail... top dollar.
   / Where to buy H / I Beams? #7
Too bad. My guy resells for about 2X what he pays for it. A screaming deal for me and an honest profit for him.
   / Where to buy H / I Beams? #8
Should be able to get scrap like that for around .25 a pound or less.
   / Where to buy H / I Beams? #10
That's some serious size beam you're talking. I used S8 @ 18.4 for mine. I think you be better of using I beam (S), the outer edge of the wide flange flange will be quite a ways fron the center verticle section (web) of the beam and might have a tendancy to pull up. Depending on your design of course so I could be full of it :).....Mike
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
2003 Big Tex 10PI...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
