Emax 22hst
/ Emax 22hst #1
gtmahindra
point pleasant nj
emax 22hst
I posted something about this before. My tractor pops the PTO 7.5amp fuse. I sent it to the dealer and they didn't find anything. Just replaced the fuse. Used it for around 3weeks but now without turning the PTO on the fuse pops. I avoid using the brake since from what I can see on the diagram they are connected? Any idea what I should be looking for. Any help would be appreciated.
/ Emax 22hst #2
Hello gtmahindra,
My dad had the same problem with his eMax 25 HST. First the dealer replaced the fuse. It worked for a bit then it blew the same fuse two more times. He had the dealer pick it up again. The dealer replaced the entire wiring harness for the tractor. I did not get to see the location personally, but the PTO shaft had wore through the harness and into the wiring. It was causing a short (if I remember correctly) and causing that particular 7.5 amp to blow. Our dealer had the same thing happen to another eMax tractor. When the dealer replaced the wiring harness on the eMax they tried to make sure that the same thing would not happen again. I think they may have rerouted the wiring harness in the tractor somehow. Like I say I did not get to see it in person. While the eMax was being repaired my dad decided to trade the eMax in and get a Max 26 XL instead. The eMax was sold in less than a weeks time, and last I heard the new owner was pretty happy with it. I hope this may help some.
/ Emax 22hst
Hello gtmahindra,
thanks. I will remove the mower deck and check the harness. I am sure there were engineers that thought this was a good idea with all the relays and safety switches but I miss the old mechanical systems.Thank you again
/ Emax 22hst
Thanks for the additional info. I pulled the mower deck and it didn't look like any of the wiring was damaged or even chafed. I think it has something to do with one of the relays since it pops the fuse without the pto being engaged, but of course not all the time, which makes it tough to find. I will keep you posted, thanks again
/ Emax 22hst #5
Unless it's way under rated for the load, blowing fuses is typically an indication of bad or faulty (i.e. shorted wiring) somewhere.
/ Emax 22hst
I figured there has to be a short somewhere but since it is inter!intent the question is where. I have a wiring diagram but that seems to be of no help. Where is the relay for the PTO located and what else is on that circuit. It seems everything else is working.
/ Emax 22hst #7
Best way to find something like this is to start at one end or the other and trace the wiring by hand until you find where the wire is either pinched or chaffed.
/ Emax 22hst
Here is the update. Where the front harness connects to the rear harness just before the plug, there is no wire loom. From the shaking of the machine in general it wore through the wiring at the frame and caused the short. When the key is turned on or off there is a split second when power is applied to the dash and all the components. Didn't realise this at first but it does. There needs to be some insulation at the plugs,harness when it rubs the frame. Check your tractors before it wears through. Thanks for the help guys. I appreciated it
/ Emax 22hst #9
I figured it'd be something like that. It usually is. Cars, trucks, airplanes, tractors etc. all the same. If it moves, look for chaffed wiring.
/ Emax 22hst #10
gtmahindra,
I'm glad you found the problem area on your tractor. I didn't what else I could contribute to help you solve your problem.
Question for you gtmahindra: Was it the wiring above the harness plug(s) {which would be above the area shown in this picture) that was wore though?
/ Emax 22hst #11
Are you going to tell the dealer that you found what they couldn't? :D
/ Emax 22hst
it is the wiring plug just out of view toward the front. No protection from rubbing the frame as the wires spread to get into the plugs
/ Emax 22hst #14
Considering the fact that finding something usually involves going through the effort of looking for it, it's little wonder he found it and they didn't. ;)
/ Emax 22hst #15
I would hate to sit across the negotiation table with you DickF. lol
/ Emax 22hst #16
Not hard, I always tried to make it a win win proposition whenever I could but I was also known to drive a hard bargain. I was usually commonsensical about most things. The mostly Chinese company I used to work for would often defer to me to make some of the more difficult deals which was high praise coming from them since they're no slouches.
2016 Audi A3 Passenger Car, VIN # WAUA7GFF5G1112525 (A61569)
2016 Audi A3...
Woods BB72 72in Rotary Brush Cutter Tractor Attachment (A61567)
Woods BB72 72in...
2020 Chevrolet Tahoe (A60352)
2020 Chevrolet...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
Zero Turn Mower (A59231)
Zero Turn Mower...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61568)
2007 Western Star...
