F3680 Center Blade Intermittent Problem
/ F3680 Center Blade Intermittent Problem #1
1bush2hog
Georgia
NH TN75
I was out mowing this past weekend with my F3680 and noticed that the center blade was not cutting the same as the two side blades, especially when cutting thru some thicker/higher grass. I could hear the blade stop turning and definitely see the path of grass that was higher in the middle. I checked the belt, and although not really tight, it was in pretty good condition. The tensioner and spring appeared OK too. When checking the blades I noticed that the spindle for the center blade was hotter to the touch than the other two spindles. I didn't have tools with me at the time to check the tightness of the blade since the mower is at some property I own out of state.
I was in a hurry to finish mowing so I just ran over the missed areas twice and got everything cut. Was going to order some new blades, blade bolts, and a new belt. Since I purchased the machine with a little over 800 hours on it, I'm not sure how new the blades and belt are either.
After looking at the parts diagram online however, I'm wondering if maybe the spindle bearing could be the potential culprit here that's causing the 'slipping' of the blade.
Anyone had any similar experiences or had to change out a spindle bearing on one of these F series mowers? Would appreciate any comments, tips, tricks, etc.
Also, I would appreciate it if someone can tell me what size socket I'll need for the blade bolt - Maybe 30MM?
Thanks
Bruce
/ F3680 Center Blade Intermittent Problem #2
I was going to guess the bearing too. I had one completely destroy itself one time.. balls were hanging out of it (as gross as that sounds!)
/ F3680 Center Blade Intermittent Problem #3
Check whether blade is tight...I've run into that a couple of times with a ZD326. Haven't encountered it with my F3680.
/ F3680 Center Blade Intermittent Problem #4
I have encountered it with my F. I took the blade off, reseated it and tightened it down with air wrench and no problem since. There seems to be a close but not correct seating that feels tight by hand but it isn't tight enough to do the job. Try taking blade off and retightening before spending money. :2cents:
Hopefully that is the solution :)
I read in your post on changing blades that blade bolt is a 30mm bolt - Is that correct? Also how often do those cup washers need to be changed out?
/ F3680 Center Blade Intermittent Problem #6
This is good advice. Also make sure all mating surfaces are clean (no grass, no oil, etc).
Torque the spindle to blade bolt down to factory specs with a torque wrench. On my ZD326 it requires fairly high torque. Around 90 ft lbs I think. Check your manual.
A slipping blade will quickly damage parts so fix it before you mow.
/ F3680 Center Blade Intermittent Problem #7
Not sure of size. I did change the cup washers one time but I don't think it was needed. I think I just hadn't seated the blade correctly.
Well I got the center blade tight but not sure that I don't have another issue. I tried tightening the blade but the spline and pto shaft would turn too even after trying to put in gear, leave in neutral, engage pto, and leave unengaged, and/or every combination thereof I think. Even with blades blocked with 6x6's the Shaft would continue to turn. I ended up putting a piece of rebar thru the universal joint on pto shaft so I could keep it from turning while I tightened blade bolt
So now I'm wondering if I may have a pto clutch/brake issue or something else or did I overlook something in process?
Any thoughts?
/ F3680 Center Blade Intermittent Problem #9
Well I got the center blade tight but not sure that I don't have another issue. I tried tightening the blade but the spline and pto shaft would turn too even after trying to put in gear, leave in neutral, engage pto, and leave unengaged, and/or every combination thereof I think. Even with blades blocked with 6x6's the Shaft would continue to turn. I ended up putting a piece of rebar thru the universal joint on pto shaft so I could keep it from turning while I tightened blade bolt So now I'm wondering if I may have a pto clutch/brake issue or something else or did I overlook something in process? Any thoughts?
Sounds like the threads in the hole or on the bolt are crossed or damaged. This would explain why the spindle turns and why your blade is loose.
Good thought but No cross threading of the blade bolt. Threads are perfect
/ F3680 Center Blade Intermittent Problem #11
When you tighten other blades do they try to turn drive shaft? The fact the drive shaft tries to turn when you have blade block demonstrates why blade isn't mowing. It's loose for some reason and not being properly clamped by bolt and washer assemblies.
/ F3680 Center Blade Intermittent Problem #12
At least the ones I have seen the belt on the middle blade runs around the pulley using the back side of the belt while the outside blades use the inside of the belt. It could be the outside of the belt is worn heavy while the inside is in better shape or it could be there is an idle pulley to help route the belt around the center pulley that is the issue. Either is damaged, missing or needs adjusting.
When you tighten other blades do they try to turn drive shaft? The fact the drive shaft tries to turn when you have blade block demonstrates why blade isn't mowing. It's loose for some reason and not being properly clamped by bolt and washer assemblies YEP.
The other two blades on the outside do not turn when I tighten the blade bolt if I have them blocked
/ F3680 Center Blade Intermittent Problem #14
There are times the cups need to be replaced!
I checked belt, pulleys, tension arm and tension spring and all are OK. The fact that the spline in the mower gearbox, and the pto shaft from machine to mower gearbox both continue to turn after I have blade blocked is the concern.
I would think that once the middle blade under the gearbox is blocked, nothing should turn except the blade bolt.
I'm wondering if these machines have a "slip clutch" :muttering:
Understood, but is it normal for the PTO shaft to turn when trying to tighten them?
/ F3680 Center Blade Intermittent Problem #17
If the blade is not turning as it should something is slipping for some reason. If one blade is slipping when the other two are not then issue is with that blade, washers, spindle, belt or pulley.
As to is it normal for the pto shaft to turn when you are turning bolts on the blade spindle, yes. You are turning the drive system. The bolt holding the blade onto the spindle is as much part of that system as the pto shaft is. What you want when you are tightening or losing a bolt is there to be enough weight in the drive system or such to keep your bolt from turning but...normally that is not true. But that is a good sign for it shows the drive train is easy to turn which it should be. It also takes a tight belt with good grip to have the full drive system to turn when you are turning one spindle using either the blade or just the bolt.
One thing I do not think has been suggested, remove the bolt from the center spindle and one other. Compare the two bolts are they the same length or by chance is the center one little longer? Does the other bolts have a washer this bolt does not? Take something even small Phillip screw driver and message the depth of the threads on both spindles. The center one may not have been drilled or taped as deep as it should have or they may be some foreign material in there. Swap the two blades, could be the center blade is not the proper thickness. Some after market blades are not as thick as the OEM blades are and that may be the issue.
I assume (dangerous) you have check to verify the blade mount is not broken lose from the spindle allowing it to turn. No idea if yours is welded on or has key or what.
/ F3680 Center Blade Intermittent Problem #18
I noticed just today, an area which was quite a bit taller because I cut it ever, 2nd to 3rd time, wasn't cut as cleanly as it should have been....and yep, it looked like it was the center blade not cutting cleanly.
I need to do some checking on mine as well. Won't get to it until the weekend.
/ F3680 Center Blade Intermittent Problem #19
Mine is now cutting terribly but all three blades are cutting. Grass this time of years gets like strings, tough strings and not sharpening blades also gives me that great bad cutting performance.:D Sharpen and inspect all three blades before deciding there is a problem with the mower and make sure your at full throttle and see if slower instead of faster makes a difference, jc.
The washer holding the blades on is cupped. Turn it upside down and it isn't going to hold. Don't get it tight enough and it isn't going to hold. Reason I use Ryobi/Craftsman battery or generic air impact wrench to remove and tighten blades on mowers.
/ F3680 Center Blade Intermittent Problem #20
Yeah either cup washers are shot, the bolt is bottoming out, bolt or spindle thread is bad. The bolt washer assembly is not clamping down on the blade.
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
Bigfoot with Bottle Metal Decorative Yard Art (A66738)
Bigfoot with...
72'' snowblower make?
2018 Manitou MLT634 7,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
