Extracting broken drill bits - my method.
/ Extracting broken drill bits - my method. #1
alchemysa
South Australia
Kubota B1550HSD
Yesterday I broke a drill bit inside a broken bolt that I was trying to drill out. No way could I get a grip on the broken drill bit so I used a method I have used in the past with success. I simply smashed the stuck drill bit to pieces with a home made punch. I googled to see if anyone else had tried this but didnt find it mentioned anywhere so I'm throwing it in here for comment.
The idea of bashing a broken drill bit even deeper into the hole seems completely counter intuitive but it has worked well for me. Drill bit metal is brittle so it breaks into small pieces quite easily. You just need to make a suitable punch that fits the hole LOOSELY. An old hard bolt, and the shank of a broken drill bit, have both worked for me. Hammering on the punch creates broken pieces that can be blown, vacuumed or tipped out as you go. You may think you are going to eventually get a hard packed wad of powdery pieces in the bottom of the hole but in fact that isn't a problem. Any wad that develops is easily broken up with a pointed tool such as a small screwdriver.
Anyone else used this method?
One other tip if you are trying to drill out a bolt. Never go deep with fine drill bits. A pilot hole should be just deep enough to give a larger bit a starting point, If you can't drill down solely with a large bit, and need to use a variety of drill sizes, work down the the hole in stages, widening the hole every few mm, so that you never have a fine bit deep in a hole where it can bind and snap. Obviously in the event that a bit does snap, and you need to use the method described above, you want to be working in the widest hole possible. Also use oil so you reduce the chances of bits binding and snapping.
Comments to correct any bad advice I might be spreading here are welcome.
(Edit, The tip snapped off another drill bit today and I basically used the same method again with success).
/ Extracting broken drill bits - my method. #2
Yesterday I broke a drill bit inside a broken bolt that I was trying to drill out. No way could I get a grip on the broken drill bit so I used a method I have used in the past with success. I simply smashed the stuck bit to pieces with a home made punch. I googled this idea but didnt find it mentioned anywhere so I'm throwing it in here for comment.
The idea of bashing a broken drill bit even deeper into the hole seems completely counter intuitive but it has worked well for me. Drill bit metal is brittle so it breaks into small pieces quite easily. You just need to make a suitable punch that fits the hole LOOSELY. An old hard bolt, and the shank of a broken drill bit, have both worked for me. Bashing away on the punch creates broken pieces that can be blown, vacuumed or tipped out as you go. You may think you are going to eventually get a hard packed wad of powdery pieces in the bottom of the hole but in fact that isn't a problem. Any wad that develops is easily broken up with a pointed tool such as a small screwdriver.
Never tried that one but I'll log it away for future use.
If the bolt is at least flush with the surface you can try my method. Lay a nut over the end of the broken bolt. The nut has to be smaller than the bolt so you don't weld the nut to the surrounding metal. Then weld down though the nut welding the end of the bolt to the nut. Put a wrench on the nut and back the bolt right out. The heat from welding also helps loosen up frozen bolts as it was likely frozen to begin with and that's why it broke off.
/ Extracting broken drill bits - my method. #3
How big a bolt are we talking? That would make a big difference on ones strategy. I know a guy that has reverse drill bits. What a luxury.
Love the welded nut idea. With my eyesight and welding skills I'd turn everything into one ruined blob!
I used to have this 16 foot finishing mower with 1/2" reverse thread blade bolts. Hit a groundhog hole or ant hill and the bolt would shear off. Ten dollar bolts! I had bolts made, anti-seized all the bolts (9 of them) then just carried a cordless drill, a small bit and some self tapping screws along with a screwdriver. That really cut down on my expenses and down time.
Necessity is the mother of invention.
/ Extracting broken drill bits - my method. #4
[QUOTE="alchemysa;4545807" Comments to correct any bad advice I might be spreading here are welcome.[/QUOTE]
Use that method a lot myself, also works well on taps that get broken. I've also had good luck starting a pilot hole with a "centering" drill bit that machinists use, they have 2short flutes and are pretty short, not much length to break and enough to help locate/start a bigger bit
How big a bolt are we talking? ....
Just to clarify. I was smashing the broken drill bit, not the bolt. The broken drill bit was only about 3mm this time, but I've used the method on larger broken bits. I think the bigger the bit the easier it would be as you can use a gutsier punch and have more room to move.
The bolts were well and truly rusted into a cast iron block of an old Wisconsin V4 that had been sitting in salty seaside air for years. I sprayed WD40 for a week, and tried a rattle gun, but in the end the heads of the bolts had to be snapped off to get the cylinder heads off the engine. But even then there was still plenty of exposed bolt left to get a grip with a pipe wrench. But no-way were those bolts going to budge. In the end i just had to snap them off at the base and start drilling. 7 of them!
/ Extracting broken drill bits - my method. #6
When I have a bolt broken in a cast iron piece I use a torch to cut\shave the bolt out. The bolt will melt before the cast iron will. Then I take a bolt and run through the threads to get the slag out of the hole. This works as long as the bolt goes all the way through the cast piece.
/ Extracting broken drill bits - my method. #7
Just don't break the end of the center drill off. No fun to get out. We use to break drill all the time in the shop and we broke up the larger ones by shattering them. What was fun hen the tip broke off one 12 or more inches in the part. We did a lot of injector drilling and those had a carbide cutter edges on the heads
and those oles were 5 or more foot in to the parts. You had to shatter the carbide which then embedded into the part
/ Extracting broken drill bits - my method. #9
I've used this method for removing broken taps. Sometimes if you chisel them in the right spot you can get them to back out. I recently used an air chisel to remove a stuck nut. This was the fan clutch mounted on the water pump of my truck. I tried hitting an open end wrench with a hammer, but that didn't work. There's no way to get a socket and impact wrench oh this. I used an air chisel to break it loose.
/ Extracting broken drill bits - my method. #11
I was a mechanic for a few years and have easyouts and left handed drill bits. The drill bits work best for me. Thanks for the tip. Ed
/ Extracting broken drill bits - my method. #12
I don't know about HF but we have Princess Auto. I have learned not to buy anything that involves metal cutting from them. Only drill bits that I ever used that became smaller rather than the hole becoming larger.
/ Extracting broken drill bits - my method. #13
You need to apply some heat.
/ Extracting broken drill bits - my method. #14
Drill a hole and hammer a torx head socket in the hole. Works 90% of the time for me
/ Extracting broken drill bits - my method. #15
If you have a hole drilled you can use an easy out. The bigger challenge occurs when you break a tap or drill bit in the hole.
/ Extracting broken drill bits - my method. #16
Used this method alot, for bits and for easy outs, I dont like easy outs because as they bight in, they can swell the shank of the bolt out and make it harder to extract. Usually try welding a washer and nut on, the heat helps alot, then I rattle them off with the impact.
/ Extracting broken drill bits - my method. #17
Shattering thi bit---- that's really good stuff, thanks for posting!!!
My dad told me once of burning a hardened bolt out of cast iron with an Oxy/Acet torch, the threads were untouched. It was a blind hole - not thru hole. The bolt shot its own slag out the hole when it ignited. Can't do this method on a stainless bolt. Or Aluminum head....
I hear ya about the pilot hole depth (& risk). Basically you should think long & hard when considering a deep pilot hole smaller than 1/8". But a hole thru allows penetrating oil to the other side, a HUGE benefit to the extractor.
Welding a nut on --- its pretty difficult to get a weld thats stronger than the bolt that broke, but the heat helps to loosen the stuck thread. A pilot hole thru to inject PBBlaster to other side is good here too.
I've never had much luck with 'easy outs' either. A bolt that is so rusted in that the head snaps off while you are trying to remove it is not coming out that easy.
/ Extracting broken drill bits - my method. #19
I have a couple sets of the HF left-hand bits. They are ok, but use them VERY cautiously! They are quite fragile compared to a good quality HSS bit.
/ Extracting broken drill bits - my method. #20
The closest I have had luck with is a set the dealership bought, basically works like hammering in a torx bit but a little more precise. Removing Frozen or Broken Fasteners | Metal Arts Press, Not the exact same thing but the same basic principal. I used it hundreds of times on broken exhaust manifold studs on fords when I worked at the dealer. Also, it was a little softer metal so as not to snap off if you made sure not to put any lateral pressure on it. If it didn't extract it was time to drill it out completely. ALSO, the one I used was in figure 6:37 on the link I posted
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
New/Unused Fuel Delivery Tank with Pump (A65583)
New/Unused Fuel...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A64557)
Year: 2016 Make...
