What's the thickest crap you've mowed? Picture Heavy
/ What's the thickest crap you've mowed? Picture Heavy #1
nikerret
Kansas
Kubota BX25D-1
Today, I decided to mow the entrance to one of the fields we hunt. Deer season is just around the corner and we wouldn't have seen anything, in here. We've hunted it the last five years, but this is the first year we've had this kind of rain. Usually, by now, it's all dead or dying.
My choices were the Echo string trimmer or the Kubota BX25D with the 60" MMM.
Kubota won!!
I didn't take any before pictures, as I was racing an incoming rainstorm.
Here, you get an idea how tall and thick it was. It was like this clear across the road.
Naw, just kidding, here it is. In this picture, you can see where I've already mowed, to the right. I was experimenting with the best way to do this. In this picture, the bottom of the bucket is about a foott off the ground:
Here, you can see it stopped at the end of the row, after I mowed the road and a big delta area, at the field entrance:
Here is a wider shot. The way it looks on the sides of the road is how it looked all over. The BX really took it down:
Here is where I went by the field, turned around, and came back. You can see the stuff knocked over, from the FEL. Not bad for only going over it twice. I had left the BH and FEL on in case I got stuck and needed to push/pull myself out.
Afterward, it was very dirty. That yellow crap is some kind of pollen; got on everything:
I didn't have any issues. I found the best way was to lower the bucket a couple of inches off the ground and then let the mower take care of the rest. The mower was left in the full up, transport position and the chute was held back, by a bungee chord. I ran it around 3,000 RPM, which is where I generally mow. It took me around 30 minutes mow. Less than 50 minutes from arrival to departure, including trailer tie down time. I need to mow my yard, in the next couple of days. I will see how it cuts before I go to sharpen the blades.
After I mowed, I moved some concrete steps to a friend's house. We used the FEL to dig down, a little bit, as the steps were going to be too high.
Getting the three step into place:
Final three step:
And the two step:
I still haven't got hooks on my bucket. We just looped the strap (has an eyelet on each end) around and used the chain to hold the strap and the rest of the chain to go around, again. We used the level indicator as an anchor point. Worked fine, didn't see any bending or damage to the area around it.
/ What's the thickest crap you've mowed? Picture Heavy #2
I've hogged thicker stuff but the tallest was this trail on a clear cut with a B2320, little LP 4' hog. The land to either side is just what it looked like before I cut it. I did have a remnant of an old trail to cut on but it was still hard to see the 'edge' to avoid dropping a tire over the ridge.
Slow & steady. ImageUploadedByTractorByNet1472532618.639955.jpgImageUploadedByTractorByNet1472532635.079422.jpg
/ What's the thickest crap you've mowed? Picture Heavy #3
I cut tree of heaven, some call them sumac that were 15 ft tall with briers all around higher than the canopy with the Gc 2400 and much bigger with the farm tractors back in the day. Looks like your tractor did a great job. Ed
/ What's the thickest crap you've mowed? Picture Heavy #4
Glad it all work out for you mowing,by the looks good engine and body cleaning air filter also will be needed.
/ What's the thickest crap you've mowed? Picture Heavy #5
Great pictures again! Amazing what you can chew up with that mower deck.
Word of caution: Be careful to avoid smacking roots, rocks, logs, old lawnmower engines or whatever else is lurking in the brush. The belly mower is really not setup to tolerate hitting objects like that. I see a 48" brush cutter in your future! If so, you may want to check out some of the aftermarket skid plate kits available for BX's. There's a plastic transmission cooling fan between the engine and the tranny that can get destroyed by sticks, particlularly if the belly mower is off.
/ What's the thickest crap you've mowed? Picture Heavy #6
Hey, I agree. You did an amazing job to have done it with a belly mower. Better tool is a small bush hog for that job but I can see you would have to pull off the backhoe or else borrow some other tractor.
/ What's the thickest crap you've mowed? Picture Heavy #7
And here I was going to post pics of a field I decked mowed this morning myself but my field pales in comparison to yours. Man, I love my BX25 though. I just snicker when the zturn mower guys shake their head at mowing some of the fields around here and I end up deck mowing it. I have a brush hog for the fields with tree stubble but if no stubble, I leave the hog at home. Good job there Nikerret.
That's why I spent a lot of time with the FEL bucket only a few inches off the ground. That way it would hit, move, or show anything before the mower hit it. Only problem with that plan is the 60" mower following a 48" bucket....For sure, a skid plate would be necessary, if I get a rear mount mower; which I would like to have, someday.
/ What's the thickest crap you've mowed? Picture Heavy #9
My Kubota F-series or a Kubota Z-turn can mow anything a MMM will mow. Our Diesel engines, shaft driven deck, and much heavier belt and pulleys makes these machines far more capable than a regular ZTR. The F-series is probably more capable than a MMM because I'll cheat and lift the deck a foot off the ground and mow it then drop the deck and mow it again. With the deck lifted off the ground it will chew up the worst of the crap while benefiting from much more efficient discharge. Of course the smartest thing to do is use the right tool for the job. image-3793574178.jpg image-2741098577.jpg
/ What's the thickest crap you've mowed? Picture Heavy #10
I have about 8 acres like this,,,
That field was cut with the sickle, the thicker, and taller, the better
When I am too lazy to walk, I got a flail mower that makes short work of the field!! :cool2:
Rooster Weathervane (A55853)
Rooster...
2016 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRUCK (A59823)
2016 FORD F-550 XL...
2018 F550 Bucket Truck (A61307)
2018 F550 Bucket...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
