Air Compressor Conversion
/ Air Compressor Conversion #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
The electric motor on my 35 year old Speedair is gone. The pump and everything else is in good shape. I have a brand new 6.5 HP gas engine that I could mount. I know that I will need some kind of unloader to release pressure as the gas engine runs constantly. Does anyone have a suggestion?
/ Air Compressor Conversion #4
Can't say I know that setup in detail.
I'd probably try and find a shop that has a fleet of road-service trucks. If they don't have some scrap units around to pull parts from, they may be able to tell you of a good source. Just my guess, for a place to start.
Rgds, D
/ Air Compressor Conversion #8
It's the TBN way.
So true. But hey its' entertaining.
To the OP. Simply go buy a new electric motor would be my suggestion. I'm sure it can be done for under $150 at HF with a coupon.
2 HP Compressor Duty Motor
Seems like it will be complicated to make the gas motor work without adding $150 in parts.
All true, but this is not my shop compressor. It's primary use is when I need air somewhere on my 26 acres. and I haven't found an extension cord long enough :laughing:. I think running it on my generator is what took out the motor. Hauling both a compressor and a 9000 watt generator is problematic.
I have a virtually new gas motor setting in the shop waiting for a job to do.
I only use the compressor a couple of time a year so I'm looking for a simple solution.
/ Air Compressor Conversion #10
How about searching around for a diagram of a commercial gas powered compressor, and seeing what they use? You might be able to grab some part numbers and cobble up your own system.
That approach should meet the TBN complexity requirements, too! :D
/ Air Compressor Conversion #12
Electric motors are cheap. The secret is where you get it and not get scalped. Try looking for a local mom n pop electric motor shop. Not the guys who rebuild your car alternators and starters but rather the ac type. They may be able to rebuild yours. If not they will definitely be able to score you one for a good price. You can often get a Dayton for less than you pay for "one of those" at HF.
I had a rental mobile home furnace's blower motor go a while back. Replacement was around $200 just for the motor . A couple other places could get one for around $180. I ended up at the local AC motor repair shop to see if they could fix it. No dice but I walked out with a Dayton for around $100. If you can fix it for that much you are far better than shopping for a new compressor.
/ Air Compressor Conversion #13
Sounds like a gas conversion is what you need. Electric motors may be cheap, but an engine you already own is cheaper. Add to that no electric service where you use it, no brainer.
The compressor on my neighbors service van will idle down when the tank is pressured up fully. If you are needing just occasional use, I would think an unloader valve would be all you would have to add.
/ Air Compressor Conversion #14
Compared to any other use of electricity, an electric motor is the most efficient use.
For the cost of running a 100 watt incandescent light bulb, I run a 48" fan in my shop.
The whole shop stays comfortable on a hot day.
When it is humid, I can pump almost 3 gallons of water a day out of the air with my basement dehumidifier, for $0.75 a day
The cost of compressing air with a gasoline engine will be high.
I use my stationary electric compressor,,, and have a 100 foot hose to make the air "portable",
Further portability is the only reason to use an engine.
/ Air Compressor Conversion #15
why do you think the genny took out the motor?
I originally had a 3500 watt generator and tried to run the compressor. After about a minute it started to release the factory smoke. I stopped it and inspected the motor. One of the points on the centrifugal switch was completely melted off. I McGivered it as the motor is 35 years old and I couldn't find a replacement part. I dug through my junk box and found an old set of automotive points that had a large contact. Silver soldered it to a piece of brass shim material and then silver soldered that to the metal spring that contacted the centrifugal mechanism. The nylon "rubbing block" was also gone so I found a small piece ofnylon and epoxy'd it to the spring.
This has worked for about a year when I could access shop power. I got a new 9000 watt running 10000+ starting generator and thought it would do the trick for remote operation. I hooked it up and tried it again, closely watching the motor. After about 10 seconds,the factory smoke started to reappear. I quickly killed it. No noticeable damage this time. Tried it again on shop power and it runs OK.
The only thing I can think of on the generator power is that for some reason the motor is not geting up to full speed and the centrifical switch is not disengaging allowing the start capacitor to remain in circuit. This will cook the windings in short order.
The 9000 has more than 3 times the power needed to run this motor which has a RLA of 12 amps.
Since I just use this compressor a couple of times a year for small projects, I think I will just install a 120PSI blow off and let it run. This motor doesn't have a governor so there is no practical way to make it idle down. I'll just manually adjust the speed to keep the pressure close to blow off pressure.
/ Air Compressor Conversion #17
One thing that hasn't been mentioned yet .... the electric motor probably runs at about 1760 rpm but the gas engine will want to run faster than that. You may have to change the drive ratio between the motor and the compressor.
/ Air Compressor Conversion #18
Sounds like a genny speed problem. Low frequency will cause slow running and will heat a motor up. Compounding that with a sticky start winding switch and youve got a smouldering fuze.
/ Air Compressor Conversion #19
9kw genny should have no problem starting and running that motor...
It's a typical 3450 230v motor. Very compatible with gas.
40' One-Trip Shipping Container (A66285)
40' One-Trip...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
2012 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2012 MACLTT 150...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
2024 CATERPILLAR CP56R PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
