Air Compressor Conversion
/ Air Compressor Conversion #41
The old Emglo wheelbarrow compressors that we owned, had two ways of operating. They had the normal on and off cycle mode with the air pressure switch, or you can open up a valve that went to an unloader valve set a few psi lower then the shut off pressure for the switch and the electric motor just kept spinning and would pump air when needed and then unload. On construction sites they could run several guns at a time and the motors actually lasted longer because of not having to start under load all the time.
My Dewalt and Emglo compressors with the Airmate direct drive compressor unit all have a type of delay/unloader valve between the pump and the tank check valve. They have a popet that
opens after the motor shuts down so there is no load on the compressor until it has pumped air for a few seconds, sometimes these will stick open and some people believe the compressor is bad (got one from goodwill that way).
David
If the compressor has a working unloader it's a whole different ball game.
I think that it's pretty common knowledge that compressors in this class have both unloaders and capacitor start motors.
/ Air Compressor Conversion #44
such a shame that a simple question regarding building a gas operated compressor turned into a generator/electric motor debate. I was looking forward to learning how to make the compressor work with a gas engine.
OP - Glad you got a resolution even if it wasn't the one you were seeking.
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
2012 PETERBILT 367 (A65643)
2012 PETERBILT 367...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
2022 EZ-GO ELITE...
Bale Spear (A66408)
Bale Spear (A66408)
