Mowing a 14x80 mobile home with a DK55... YES!
   / Mowing a 14x80 mobile home with a DK55... YES! #1
quadmaster50
Bloomington Indiana
Bobcat T770, T650, 435, Case 450C
My neighbor is building a new house and been living in a old trailer and needed it moved, They had a dump truck hooked to it and a 2wd 70HP international on the back pulling and still couldn't move it... Well, I offered to try with my little Kioti and it moved it without even spinning a single tire.... Trailer was still full of all their stuff also....
Im impressed with the little things!!
   / Mowing a 14x80 mobile home with a DK55... YES! #2
I was expecting a photo of a mangled one after backing your brush hog into it.
Bruce
   / Mowing a 14x80 mobile home with a DK55... YES! #3
Bruce
Ha! I was expecting some sort of homemade, 'Redneck Engineered', 3PH, multi-head, weed-whacker set up. :laughing:
   / Mowing a 14x80 mobile home with a DK55... YES! #4
Lol quadmaster50 in some circles the title would be called click bait, I was ready to see you bush hogging a trailer. Never the less nice to see you beat out the international.
   / Mowing a 14x80 mobile home with a DK55... YES! #5
I am currently looking at the NX5510 and noticed (in the shop manual) the towing spec as 9,500 lbs. I'm going to be getting a dump trailer and was going to be using my truck to tow it just in my immediate neighborhood to move a bunch of material. I'm now thinking that if I get the tractor I could just use it: it'll be loading the trailer, as well as spreading the material around.
Yeah, impressive!
   / Mowing a 14x80 mobile home with a DK55... YES! #6
I am currently looking at the NX5510 and noticed (in the shop manual) the towing spec as 9,500 lbs. I'm going to be getting a dump trailer and was going to be using my truck to tow it just in my immediate neighborhood to move a bunch of material. I'm now thinking that if I get the tractor I could just use it: it'll be loading the trailer, as well as spreading the material around. Yeah, impressive!
On flat ground the towing capacity is anything it can move.
   / Mowing a 14x80 mobile home with a DK55... YES! #7
And that would be solid ground!:thumbsup: (I've got flat ground that you can readily get stuck in:eek:)
   / Mowing a 14x80 mobile home with a DK55... YES! #8
The towing capacity is still anything you can move. It's just a lot less.
   / Mowing a 14x80 mobile home with a DK55... YES! #10
Yup. (I've moved massive tree trunks with my dinky B7800- spinning them.)
Just found it interesting that the manufacturer's specs were that high. Towing specs are generally based on the expected operational environments that the equipment will be operated in.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Pig Statue (A55853)
Pig Statue (A55853)
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
2007 Toyota Corolla LE Sedan (A55853)
2007 Toyota...
16FT box truck (A53422)
16FT box truck...
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
