Backhoe seating 2601/2650
/ Backhoe seating 2601/2650 #1
Lilguy
Chicago, Illinois
Kubota
I have been given 2 different explanations of the seat that one ends up with when adding a backhoe to a 2601 or 2650. One dealer says you get a swivel seat with the mounting kit. Said I can have the factory seat if I want it. Second dealer first said the backhoe comes with its own seat. I challenged that point with the brochure showing a new swivel seat option, they checked and then said you get a swivel base for the factory seat.
Anyone have either unit with BH and what is reality? Thanks
/ Backhoe seating 2601/2650 #2
Kubota has mounted the backhoe close enough to the tractor so that the main seat when adding the backhoe does get a swivel base on both units in question. The seat is the same as on the standard tractor and it is just a replacement of the base to gain the swivel.
/ Backhoe seating 2601/2650 #3
Yep!
On the L series they add the second seat like the dealer mentioned.
/ Backhoe seating 2601/2650 #6
/ Backhoe seating 2601/2650 #7
On the b2650 cab, the bh77 backhoe has a spacer that move the backhoe back further. This configuration has its own integral seat
2019 Chevrolet Tahoe (A64194)
2019 Chevrolet...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
ETNYRE FWD CHIP SPREADER(INOPERABLE) (A67714)
ETNYRE FWD CHIP...
2009 IHI IC70-2 CRAWLER CARRIER (A65056)
2009 IHI IC70-2...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
PALLET OF METAL BRACKETS (A68842)
PALLET OF METAL...
