New L2501
/ New L2501 #21
Don't go ruining our dreams with your logic and reasoning! : )
Hahaha! Yeah! I was all excited to wind up my L2501 when I get it. Now it's for naught. Haha
/ New L2501 #22
If I could have got that price last year I'd have a much bigger tractor. Nevermind the fact that is't too big for my property I probably would not have been able to say no.
They are actually about the same as a B2650 in size. But are built heavy and equipped with higher displacement engine. Can't have a MMM though.
/ New L2501 #24
Check it out, my "540" speed is 2200 rpm and Max rpm seems to be 2800.
Be interesting to PTO dyno the L2501 at 2800 rpm engine speed and see what the HP is. I bet it's more than 25!
/ New L2501 #25
When kubota had to go to Tier 4 engines, model change L3200 & L3800 to L3301 and L3901 - I'm sure they had left over engines that they had to do something with... Pretty sure when kubota upgraded from L2800/L3400 to L3200/L3800 - they created a model L3700 to use up the "spare" parts from those previous models.
The L2501 has a bigger engine than my L2800... would also like to know the actual HP.
Other thing I find weird is the 540 PTO markings.... Mine shows just under 2500 rpms which is what was listed for the DT (gear) models but for my HST it should be 2650-ish (I forget exactly off hand).
/ New L2501
I know how much everyone loves pictures!
/ New L2501 #27
I know how much everyone loves pictures! <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=478385"/>
Awesome! Already dirty! How do you like it?
/ New L2501
I like it so far. Already bush hogged 4 acres, pulled 3 windblown trees out of the woods for firewood processing and pushed the tops into a pile for burning. Kens bolt on hooks being ordered today.
/ New L2501 #29
Sounds good! Is it HST? Curious how it performs with the Bushog.
/ New L2501
Yeah hst, I got the heavy duty land pride 60" with the slip clutch. Took down 3 ft tall wet grass and some overrun blackberry bushes with no problems.
/ New L2501 #33
Sounds like it has plenty of power! That good to hear. I hope to order one next week. (0: Thank you for your help!
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
