545 Steering Cylinder rebuilt.
/ 545 Steering Cylinder rebuilt. #1
Mclynn1225
Cullman, Alabama
Farmtrac 545
Just had the cylinder rebuilt. It lost a ton of reddish fluid. They guy that rebuilt it said it was just power steering fluid. Is this true and where do I replace the fluid at. I have looked all over this tractor.
/ 545 Steering Cylinder rebuilt. #2
I wish I could have gotten mine rebuilt for $100. The kit cost $80. The pump is forward of your left foot as you sit on the tractor just behind the sheet metal shroud for the radiator. Small round metal cap. I filled mine while it was running with power steering fluid.
Yea. I found it earlier. Thanks for the reply. A mechanic put me on a hydraulic shop that rebuilt cylinders. They done a good job and had it back in less than 8hrs. Do you have a 545 if so do you know where I can get a owners manual. I have a parts manual just can't find an owners
/ 545 Steering Cylinder rebuilt. #4
I have a Farmtrac 545 and just blew the steering cylinder gasket. My tractor only has 128 hrs, but about 7 years old and used for mowing only a few times a year, so it sits alot. Been told that age causes seals to dry up. My biggest concern though is another hydraulic leak that I have had fixed before and is back from a $15 elbow part where the fluid returns to the case. Last time we had to take the tractor apart to replce it because of a nut holding in place inside the tractor. Cost a lot for labor. Has anyone else had this problem?
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
2025 MB27 27in Mixing Bucket Skid Steer Attachment (A61572)
2025 MB27 27in...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2011 JACK COUNTY 130 BBL VACUUM TRAILER (A63569)
2011 JACK COUNTY...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
