What is this?
/ What is this? #1
Jimbrown
Tombstone Az
KIOTI LK30
LK 30. What is thing? I can't find any thing in my manual as to what it is. I found one picture in the shop manual that called it an oil fill. I always add oil thru the valve cover. Never noticed this before because it is painted all grey. Is it really a fill for the crankcase?
/ What is this? #2
That does look like the oil fill to me. I was told to never fill thru the valve cover.
/ What is this? #3
It all goes to the same place. Can't think of a reason why you can not.
/ What is this? #4
This is where you are supposed to pour you engine oil into the crankcase. Pouring it into the valve cover has caused some hydrolocking problems if the oil is poured in too fast. So I have heard. I can't prove it. On my DK35se engine is a similar port near the fuel injector, I have always put in the engine oil into this port. NOT the valve cover.
/ What is this? #5
On my DK 35, I have a fill plug on side and one on top. Lots of discussion about this over the years. Theory why not to use top fill is that there are baffles that slow the oil draining into the crankcase, oil can then back up into the vent hose and other places if allowed to continue.
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
UNUSED CFG INDUSTRIAL MX12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
Attention (A57148)
Attention (A57148)
2023 Case TV380 (A62177)
2023 Case TV380...
UNUSED RAYTREE RMDM72-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
Kholer Magnum 10 Compressor (A63118)
Kholer Magnum 10...
