willysmb
Does anyone make a smaller tractor (60HP or less) with a can & backhoe where you can operate the backhoe from within the cab? It seems like all that I find either can't fit with a cab or require operation from an outside seat.
Uh oh. Did I ask something I shouldn't have?
Their are cabs available (aftermarket) that allow most of the tlbs' mentioned to be operated from inside. I have a JD 110 with a Laurin cab that has worked out well. Not as quiet as a factory cab but everything else has been fine. Most of these Laurin and Boxer cabs are made for many models and are well thought out imo. With limited production compared to factory cabs these are a little more costly, I paid $7,500 for mine. Had I waited for Deere or Kubota it would be a long wait as these are still not offered.
I might look at the L47. I don't know why but it bugs me having a separate seat for the backhoe like a lot of them do.
I haven't found that needing to detach the FEL is a problem. If clearance is an issue, the bucket can be removed from all of the Kubota TLBs but since they are quite small to begin with, I don't find the need to remove anything. Mine came with the 3 PH but so far in 5 years, I haven't needed to use it. The only time the backhoe has been off was when I bought it and the previous owner showed me how to take it on and off which was super easy. He used it to bush hog with a 5 foot mower but since I didn't buy the mower and already had another tractor, I haven't ever had it off.If a lot of your work involves digging and moving material (more than 50% ???), a TLB that can also handle 3 pt and pto powered implements makes good sense. If you're mostly doing other chores (mowing, cultivating, etc.), and sometimes need a backhoe ( less than half the time), a CUT with an add-on backhoe might be more suitable. For me, being able to easily detach the FEL for mowing chores (which you can't do with a TLB), more than made up for the two seat hassle with the backhoe, but that's a personal preference thing.
