226D rear drive problem
/ 226D rear drive problem #1
ancientlake
Northeastern PA
Yanmar YM226D, AC 653 Crawler Dozer, lots of JD 200 series garden tractors
Hello,
Haven't been on this forum in years. Finally have a Yanmar again.
Bucket hit a hidden stump full tilt on my 226D. Heard a metallic snap sound and now shaft to rear drive is not turning. Shaft does turn when tractor is pushed/wheels manually turned. Front drive works fine. Took shaft cover off and both ends look ok.
Anything easy (shear pin etc) or do we need to get into the front axlel? I won't be doing that because I am obviously not a real mechanic.
Thanks,
Chris
/ 226D rear drive problem #2
Little confused. Thinking you lost 4 wheel drive? Does the shaft turn coming out of the drop box when 4 wheel drive is engaged? Might have to jack it up to do some trouble shooting.
No drive at all without front drive engaged. Front drive only (I assume) when 4WD engaged.
Thanks
/ 226D rear drive problem #4
Oh me! Sounds like a stub axle (final pinion) broken. Could be sheared ring gear bolts. What happens if you mash the differential lock with the 4 wheel drive not engaged?
Thanks. Away from the tractor the next few days, but will check out what the differential lock does when I get back. Can't imagine it would have any effect since the shaft to the rear isn't turning.
Chris
/ 226D rear drive problem #6
Chris
What do you mean by the "shaft to the rear"? It is inside the bellhousing/transmission. How can you see it?
Hi,
Sorry for my lack of knowledge/terminology. The shaft that runs from the front axle to the rear axle (prop shaft?). I slid the covers off it so I could see both ends. Thanks,
Chris
/ 226D rear drive problem #9
The front axle is driven by the shaft you are talking about. The main drive shaft from the engine enters the transmission at the back of the clutch housing. Power goes from there through gears on to the drop box that drives your front wheel drive. Sending you a PM.
ok gotcha. Will check your pm, and refrain from more posting until I do a little more homework!
Thanks,
Chris
/ 226D rear drive problem #11
yea you have snaped the main shaft in the transmission I think that powers the rears. Or like Winston said sheared the ring gear...or snapped or rung off an axle, that is why he wants to see if a rear will turn if the diff is locked. If you know the front axle is pulling you still have front drive and the shaft you see to the front axle is fine and working.
There is no shear pin in the drive line.
Yes, Winston got my head straight via PM. Just had a chance to check a few more things and here's what I know:
Rear left does have drive when diff lock is engaged.
PTO works normally.
Jacked rear right and it freewheels even when in gear (although with a bit of mechanical resistance)
Start it up, put it in gear, and rear right will turn, but feebly and can be stopped by grabbing the tire.
Thanks everyone for the education: Guess I was sick that day!
/ 226D rear drive problem #13
Sounds like the right final pinion (brake shaft) is broken. Part #194430-33410. Opening up will be only way to tell for sure.
The problem was precisely what Winston described. Took awhile to get parts but I am back in business.
Thanks all,
Chris
Kobelco SK135SRLC-1E, Cab, Heat/Air, Manual Thumb8 (A62679)
Kobelco...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
