3rd eh SCV
/ 3rd eh SCV #1
Hammerhead800
Newfane New York
John Deere
I have a John deere 4044r that I just installed a 3rd eh SCV on. It operates extremely slow and doesn't build any pressure. If I actuate the 3rd SCV and another SCV at the same time the 3rd SCV will operate at normal speed and builds pressure.
Any ideas as to what might be causing this problem?
/ 3rd eh SCV
It is a factory eh SCV. It bolts right on to the end of the 2 spool loader valve thus adding the 3rd. The 3rd eh SCV has 3 ports on the mounting face that match up with 3 ports on loader valve .there are no external supply or return lines. It has two external ports for the supply lines to a cylinder.
/ 3rd eh SCV #3
That sounds like a diverter valve, not a true 3rd function. It diverts an existing line (lift or curl) when engaged. If so, you hit the button to engage the diverter, then use the appropriate (lift or curl) lever to operate the 3rd function.
/ 3rd eh SCV #4
Cab or open station?
Did your dealer install or did you do it?
Do you know kit number?
/ 3rd eh SCV
I installed the kit. If I remember right the number is BLV10763. It is a cab tractor. My tractor also has dealer installed four and five remote rear valve which is piped in to the loader valve.
/ 3rd eh SCV
If I do that both functions operate but the third operates faster than the other function until I release the button or the third function is completed and then the other function will kick into full pressure and speed.
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
Ingersoll Rand DD-24 Tandem Smooth Drum Vibratory Roller (A64553)
Ingersoll Rand...
2020 Deere 670GP (A64126)
2020 Deere 670GP...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2016 Ford F-250 Knapheide Service Truck (A64194)
2016 Ford F-250...
