Help! Tractor/Loader/Backhoe Suggestions Needed
/ Help! Tractor/Loader/Backhoe Suggestions Needed #1
HarleyMonster
Member
Temecula, CA
Kubota L47 & L3200
I have a new, heavily optioned Kubota L47 backhoe on order, it has been delivered to the dealer, now I am finding out Kubota has put a hold on the Top & Tilt dealer installed option and there are no Kubota 4N1 buckets available anywhere.
I am quickly losing my confidence in Kubota.
The L47 is a new design, but now I am finding out Kubota has flaws in this design. It has been 9 weeks since I placed my high priced order, it was to be 3 weeks for production and a week at the dealership. Now they are telling me it will be at least another 4 MONTHS for Kubota to figure this out.
The dealer wants to install an aftermarket Top & Tilt system. My position is if the engineers at Kubota can't figure out how to put a Top & Tilt on their brand new L47 how in the world is a mechanic working out of a shed going to design an aftermarket system that I will not have problems with once I take delivery. Space it tight for a Top & Tilt when the backhoe is installed so it will be difficult to field design a system that doesn't have interference issues. My 1998 Kubota L35 is a dedicated TLB, so I wanted a new TLB to replace it. The only problems I have had with my L35 is with after market parts that were installed before I owned it.
So my question is: Is there a Compact Tractor built other than Kubota that is a dedicated TLB from the factory?
I know I can buy a tractor with a sub-frame mounted backhoe, but are any being produced like the L47 where you only have to swivel the seat to use the backhoe? I do not want a tractor where I have to get off the tractor and remount it to use the backhoe and every time I need to move it during backhoe use. My farming operation does not lend itself to full sized backhoes; I need a compact tractor.
I am ready to walk away from this deal, any suggestions?
/ Help! Tractor/Loader/Backhoe Suggestions Needed #2
Here are used industrial loaders for sale on eBay, near Temecula. Will provide an idea of alternative brands.
LINK: Backhoe Loaders | eBay
/ Help! Tractor/Loader/Backhoe Suggestions Needed #3
I think your stuck with Kubota if you want something comparable.
I lust after the M62, and would only add a factory cab if they had one available.
I'm sure it's aggravating dealing with the delays, but try to
Think long term, over the course of the many many years of ownership, this delay and aggravation will be insignificant in the long run.
Have you checked with other dealers? Try looking at dealers far away who are willing to ship.
/ Help! Tractor/Loader/Backhoe Suggestions Needed #4
I think they stopped making them, but the JD110 was a good unit. Maybe you could find a clean used one?
/ Help! Tractor/Loader/Backhoe Suggestions Needed #6
Top and tilt is really rather simple so I kind of wonder if the problem is not figuring it out, but maybe getting the parts or a quality issue. I personally would do an aftermarket setup and get to using the machine.
/ Help! Tractor/Loader/Backhoe Suggestions Needed #7
Could the problem with Top-N-Tilt be the rear remotes for the L47? I added my own remotes on my L39, powered off the swing pump. I have to take them off for the backhoe. It is just two bolts and two hydraulic quick connections so it is not bad, but it would be nice to have the factory ones that could stay on all time.
I don't know when the L45 was discontinued, but have you called around to see if any dealers have a new one left in stock?
I looked hard for a clean JD110 back in 2009. Everyone I found was pretty beat up. I eventually found a very clean L39 and have been quit happy with it.
My problem has been solved.
Kubota's problem was with the cylinders on the T&T an outside vendor was producing for them, the hole in the fork on the cylinder's shaft was in the wrong location and did not allow the 3PH to have full travel and at the same time they were not happy with the quality of the cylinders. They have found a new vendor, but they are estimating 3 to 4 months before they receive the product, it has to go through engineer, legal, production, shipping and all of that.
The dealer is going to install a T&T using Gearmore cylinders, all the rest will be Kubota. I was told if the aftermarket stuff is on the original invoice it will be covered by the Kubota insurance.
I was concerned the engine in the L47 might be troublesome and I was told this same engine has been used in Kubota and other manufacturers excavators for about 4 years and has proven to be bulletproof, so I am good with that too.
Looks like I will be getting my tractor in about 2 weeks, the 4N1 bucket is on its way.
/ Help! Tractor/Loader/Backhoe Suggestions Needed #9
You'll forget about any and all the aggravation the first time you fire up your new tractor on your own land! That is a really nice machine! You know we will all be waiting for (action) pics after you get it....
/ Help! Tractor/Loader/Backhoe Suggestions Needed #10
Excellent - glad to hear it was a quality issue that they are correcting. Not unusual for a glitch in production that is really outside of the manufactures control.
ENJOY !
/ Help! Tractor/Loader/Backhoe Suggestions Needed #11
Kubota's problem was with the cylinders on the T&T an outside vendor was producing for them and at the same time they were not happy with the quality of the cylinders. They have found a new vendor, but they are estimating 3 to 4 months before they receive the product, it has to go through engineer, legal, production, shipping and all of that.
I have always read here the mantra: Kubota produces everything used on Kubota branded equipment.
There are intermittent use cylinders and industrial cylinders. Industrial cylinders are bored and/or honed with all fittings installed. In operation, less friction, less heat and greater reliability/longevity. Significantly higher production cost to bore and/or hone with fittings installed.
I hope your problems, save inevitable shakedown problems during the first 100 hours, are resolved.
/ Help! Tractor/Loader/Backhoe Suggestions Needed #12
Last December when I decided to buy a new backhoe, there were NO L39's or M45's anywhere in the southeast. All were sold as soon as they arrived at the Dealer. So, I bought the only B26 in this part of the world. Ain't it funny how God can work things out? it turned out to be exactly what I need after all. Hope all goes well with your new tractor!
/ Help! Tractor/Loader/Backhoe Suggestions Needed #13
Harley,
Good to hear you have the problem worked out and it is not an actual issue with the backhoe. You will be amazed what you can do with it. Hope you included all the options.
/ Help! Tractor/Loader/Backhoe Suggestions Needed #14
Sure you will love it. I miss my M59. It was a handy size and very capable. I have a full size backhoe now and I must admit I enjoy the cab and it will sling dirt faster but it is not near as handy for little chores like the m59 was. I used the 59 for all types of things almost on a daily basis but I find myself only using the 310SJ when I need to do actual backhoe work. It is just too big and clumsy for many things.
/ Help! Tractor/Loader/Backhoe Suggestions Needed #15
I move my 110 around town all the time and am glad I bought one easy to trailer. The same thing would apply to the M59 or M62. A Laurin cab with hvac is a good addition to any of these. Not as quiet as a factory cab though.
There are times I need a full size hoe but you can't have everything.
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
(35) Poly Feed Pans (A66408)
(35) Poly Feed...
2018 RAM 2500 (A65643)
20ft Jumper Cables (A65583)
20ft Jumper Cables...
(4) Brawler 40 x 9 x 13 Skidsteer Tires (A66408)
(4) Brawler 40 x 9...
2015 UTILITY TRAILER MFG. CO. PUP (A65643)
2015 UTILITY...
