Steiner accessory DYI
/ Steiner accessory DYI #1
Anchored
Wooster
Steiner 420 and Kubota L3200
Has anyone ever fabricated a small dump/tool carrier/tote on the back of a Steiner 420
/ Steiner accessory DYI #2
not yet but i have thought about building one for my ventrac or Steiner 420. I would be interested in any thoughts or ideas you had.
/ Steiner accessory DYI #3
DYI?
Drive yourself insane trying to figure out the acronym.
/ Steiner accessory DYI #4
Does your stiener have the 3pt hitch?. Some do, some dont. My 430max does. with the 3pt hitch, it would just be a matter of building a small box or tray to hook to the hitch. set it off/on when needed. I have never been a fan of the diverter valve Stiener used to change the fluid from the front hitch to the back hitch, they should have used a seperate vavle so you could use either the front attachment or the rear, the way it is now, you either run the front, or you run the rear and I found that aggravating when ever I tried. Never built a carrier for my machine, instead I bought a Ventrac and the Stiener is now just rusting away. I should just sale it, it only has about 400hrs on it and hasnt been out of the shed in several years.
/ Steiner accessory DYI #5
Better yet send it to my way for free. It'll get used for sure
2010 Dodge Charger Sedan (A61569)
2010 Dodge Charger...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2024 John Deere 6R 130 Tractor Loader (A63109)
2024 John Deere 6R...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
2013 Freightliner Road Tractor (A61165)
2013 Freightliner...
Bobcat MT85 (A60462)
