Got my new 2538 today
   / Got my new 2538 today #1
screamin400
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
New 2538hst got delivered today with fel and some other stuff. Nice tractor so far. Quite a step up from my Yanmar sc2400. Put about 4 hours on today and really liked the tractor.
   / Got my new 2538 today #2
Cool..!!!!!!!!!!!!!!!!!! :) Don't forget to stop and take a breath. Then post pictures.......... :)
   / Got my new 2538 today #4
Congratulations. We like pictures if you can post some.
Have to take a look at putting up pics later. Probably beyond my capabilities. :) Tractor is working out very well. Can push down some good size trees. Box blade comes in more handy than I thought. May build a second story in my pole barn to store my implements. I can put them up there with the loader forks. Very nice setup so far.
   / Got my new 2538 today #6
Congrats, enjoy your shiny red new tractor.
   / Got my new 2538 today #7
I've been eyeing a 2538 for a while now. I took one for a quick spin at a dealer last week and I have a few questions for you.
Is it hard to get the range selector in gear? (the one I drove was near impossible)
If you use the FEL to list the front wheels off the ground, does the hydraulics leak down?
Do you know if the 2538 has a OBDII port on the engine harness?
   / Got my new 2538 today #8
Congrats - You're going to love it! Ours has been very versatile, especially with a grapple. Such a good size for precision work, but with plenty of heft to get things done.
Is it hard to get the range selector in gear? (the one I drove was near impossible) - It gets easier as it works in over time. If you find it tough, just quickly rock the forward/reverse pedals and it should align that way. Certainly not quiet as smooth as the range selector on a car or truck, but I don't mind it at all.
If you use the FEL to list the front wheels off the ground, does the hydraulics leak down? Mine doesn't leak down, but I have not left it in that position for long. Just back blading or pushing back out of a mud bog. There is no leakage with weight on the loader and being lifted up...
Do you know if the 2538 has a OBDII port on the engine harness? I think they all do now. Have not used mine yet, but I believe it is the universal OBD II harness. Please confirm that one.
Responses above in bold italics. Also check out this thread here for a lot of good info and discussion on the machine: http://www.tractorbynet.com/forums/mahindra-buying-pricing/348064-info-mahindra-2538-a.html
Is it hard to get the range selector in gear? (the one I drove was near impossible) It is very tight. Rock it a little and it works fine. It is a non issue for me as I usually am only in low range. When I do shift it just seems tight.
If you use the FEL to list the front wheels off the ground, does the hydraulics leak down? None that I have noticed.
I do not know.
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
CATERPILLAR 299D3 XE SKID STEER (A60429)
CATERPILLAR 299D3...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
