Got my new 2538 today
   / Got my new 2538 today #1
screamin400
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
New 2538hst got delivered today with fel and some other stuff. Nice tractor so far. Quite a step up from my Yanmar sc2400. Put about 4 hours on today and really liked the tractor.
   / Got my new 2538 today #2
Cool..!!!!!!!!!!!!!!!!!! :) Don't forget to stop and take a breath. Then post pictures.......... :)
   / Got my new 2538 today #4
Congratulations. We like pictures if you can post some.
Have to take a look at putting up pics later. Probably beyond my capabilities. :) Tractor is working out very well. Can push down some good size trees. Box blade comes in more handy than I thought. May build a second story in my pole barn to store my implements. I can put them up there with the loader forks. Very nice setup so far.
   / Got my new 2538 today #6
Congrats, enjoy your shiny red new tractor.
   / Got my new 2538 today #7
I've been eyeing a 2538 for a while now. I took one for a quick spin at a dealer last week and I have a few questions for you.
Is it hard to get the range selector in gear? (the one I drove was near impossible)
If you use the FEL to list the front wheels off the ground, does the hydraulics leak down?
Do you know if the 2538 has a OBDII port on the engine harness?
   / Got my new 2538 today #8
Congrats - You're going to love it! Ours has been very versatile, especially with a grapple. Such a good size for precision work, but with plenty of heft to get things done.
Is it hard to get the range selector in gear? (the one I drove was near impossible) - It gets easier as it works in over time. If you find it tough, just quickly rock the forward/reverse pedals and it should align that way. Certainly not quiet as smooth as the range selector on a car or truck, but I don't mind it at all.
If you use the FEL to list the front wheels off the ground, does the hydraulics leak down? Mine doesn't leak down, but I have not left it in that position for long. Just back blading or pushing back out of a mud bog. There is no leakage with weight on the loader and being lifted up...
Do you know if the 2538 has a OBDII port on the engine harness? I think they all do now. Have not used mine yet, but I believe it is the universal OBD II harness. Please confirm that one.
Responses above in bold italics. Also check out this thread here for a lot of good info and discussion on the machine: http://www.tractorbynet.com/forums/mahindra-buying-pricing/348064-info-mahindra-2538-a.html
Is it hard to get the range selector in gear? (the one I drove was near impossible) It is very tight. Rock it a little and it works fine. It is a non issue for me as I usually am only in low range. When I do shift it just seems tight.
If you use the FEL to list the front wheels off the ground, does the hydraulics leak down? None that I have noticed.
I do not know.
9000 (A47477)
9000 (A47477)
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
Zero Turn Mower (A59231)
Zero Turn Mower...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
