Backhoe John Deere controls to Cat style
   / John Deere controls to Cat style #11
This is the type of hose arrangement I was thinking of.
Bruce
That's what I need to look at tomorrow, wasn't sure if the hoses just go to the cylinders at the bottom or to a solid line like that
You are right Tom, the hoses go out to all of the cylinders. I just sent an email to the woods guy this morning, I will hopefully see what he says about this by the time I get off work. Seems like maybe it had something to do with the swing speed control.
Thanks for sending that on to me but it appears that it might be a little different application then what I have, I will take a closer look at it when I get home. I seems arc weld was right, you can't just change hose positions because of the relief valves. The woods guy said that I would be bending and breaking things. He said that it was a pretty labor intensive job as far as time goes to change it over. Long story short, I think I might be getting used to JD controls!
   / John Deere controls to Cat style #16
It doesn't matter how long it takes if you can do it yourself. Just need to know the proper way to do it.
   / John Deere controls to Cat style #17
Amazing how hard it is to unlearn those muscle memory tasks - good luck with it.
Jim
Thanks Jim, like rustyiron said your hands just take over when you sit in the seat. Ya, I agree with you arc weld, I don't mind spending the time to do it, I just wish I had some kind of reference to go by. I've always fixed my own stuff but I haven't messed with hydraulics very much other than changing out a cylinder or something like that. I guess it's not a bad idea to get the feel of the JD controls anyway. I'm kinda surprised that I have never came across them before anyway. I sure appreciate all the input from you guys, hopefully I can be of help to one of you guys on something!
   / John Deere controls to Cat style #19
Yep, didn't expect it to be exactly like your situation just wanted to show that just moving hoses may not be the best route to go. But like you mentioned...once a machinery operator knows one system they can typically learn another in a relative short amount of time.
   / John Deere controls to Cat style #20
So when were you up in this neck of the woods?
My mistake, never been up into the pan handle. Hayden sounded familiar, I had to look at the map, it's been 15 years by now. We made a big southern loop around the state, that was the summer after Yellowstone burned, prolly 16-18 years actually.
Just re-learn the JD controls as long as you don't have to jump on an excavator now & then, but a lot of them have a valve that let's you switch back & forth.
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
WB Mower (A50120)
WB Mower (A50120)
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2008 Bobcat T190 Compact Track Loader (A57024)
2008 Bobcat T190...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
