rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,749
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Hersheyfarm:
I have the exact symptom on my L5240. I get a couple of drips out of the clutch drain after shutting down the machine, but my driveshaft cover also has several drips and when I pulled it off to split the tractor, there was oil trapped in the cover. I do however add UDT to the front Axle. I check and top it off once a month or so.
The transmission SUDT never goes down. Others have suggested that I replace the output shaft seal while I had my machine apart, but only having 50hrs on the machine since it was done by the dealer I bought it from, I am hesitant to mess with the seals. With the fluid loss in the front axle, It is highly likely that the pinion seal is bad in the front axle. Whenever I check my front axle, a hiss of air comes out as I turn the plug out. I know it is under pressure. Maybe fabricating a vent for the fill plug is in order.
The M59s have a vented front axle. The way it works is a rubber hose leads from a fitting on the top of the axle housing up to a metal upside down "U" tube just inboard and attached to the bracket that supports the radiator overflow reservoir. On the axle, thevent is located on the op in the middle and nearly in line with the axle pivot. Putting it there keeps the rubber vent tube from flexing so much as the axle oscillates. But better check it. On mine one of the zip ties guiding the rubber vent tube was put on in such a way that it crimped the tube and made venting problematical. Still, the venting must have worked a little bit because there's no leakage out the drive seal.
Bottom line if that if your axle housing is hissing, then it's time to rig up some venting that works. All of the axles ought to have them. Maybe yours does and it's plugged or crimped.
luck, rScotty
