Clutch adjustment on a L3650
   / Clutch adjustment on a L3650 #1
gwdixon
Elite Member
Northern CA
A friend has a L3650 and the clutch seems to be slipping from his description. It has 1200 hrs and the clutch has never been touched.
He said that he checked the WSM and it had all of the parts, etc. but no specific instructions on how to adjust the clutch.
Does anyone have a diagram or method to adjust the clutch? Probably any older L-series would likely be the same or similar.
A search here and on Google didn't turn up anything relevant.
   / Clutch adjustment on a L3650 #4
it only takes a small amount of rust on the clutch fork suport rod to stop clutch working i found out om my l3600.no greese fiting here. got to keep them out of the rain,b.
   / Clutch adjustment on a L3650 #5
About a week ago I ask advice for buying a 1989 47hp.....well I passed it up.....now I looking at a L3650 ,FEL,Backhoe...one owner..
Any comments on this tractor out there
I have 60 + acres of hay field and horses....I know I would use it..but don't want to spend $ on upkeep of older tractor....is this the one for me.
   / Clutch adjustment on a L3650 #6
Best advice is... start your own thread, with relevant title. This thread... over 4 years since last post...
Edit... if you're mechanically inclined, I would go for it. My friend has a similar L2850, I've done extensive work to it, and parts availability is good, and it's comparably easy to work on...
   / Clutch adjustment on a L3650 #7
The L3650 is a very good machine - no weak points, no recurring issues. An older L3650's upkeep is about the same as on a new machine. The L3250, L3450, L3650 machines are a perfect size - compact enough to fit into a garage or small barn, but big enough to handle 5-6 foot attachments.
If this one's backhoe is the 3-point hitch type (most common on these) check very carefully for cracks or weld repairs anywhere on the machine.
Used tractors end up in one of two categories. The first type (and most desirable) is the typical homeowner machine with less than 2000 hours on it, that still looks good, no leaks, all sheet metal present and intact, no blue smoke, pto and travel clutches engage and release correctly, maybe worn tires but no major obvious battle scars. The other type violates many or all of these, usually from a life of hard use by multiple operators (rental or other commercial setting).
Used tractors are often fairly easy to get an impression of. They tend to show their experience right on the surface. If you post some pics some useful comments may come from the group. Take care, Dick B.
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
IRONCRAFT 84" ROTARY MOWER (A51243)
IRONCRAFT 84"...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
