Next year food plot
/ Next year food plot #1
jack707
up North wisconsin
farm trac 555
Now that I disc it to level out the high spots now it's ready to plow!. This field
Took a lot of work first I had to brush hog all the weeds that was a wild ride! uploadfromtaptalk1467314315874.jpg
/ Next year food plot #2
how well do the crops due around the pine trees? always thought the needles were a problem? over here more maples, popple, birch, basswood..
I heard that to about pines so maybe I'll cut it down. Don't know about the crops growing here because when I plant it will be my first time just took a sample of dirt to the local Co op to find out how much lime I need.
/ Next year food plot #4
My guess will be that you'll need a good bit of lime. Pines make the soil quite acidic and need that lime to get the ph where it needs to be. Getting a soil test is always a good idea.
/ Next year food plot #6
We just did 2t/ac on ours. Had to get pellet lime and spread it with our broadcast spreader because we couldn't get the big spreaders into the plots to do ag lime.
These were all worked from over grown scrub brush and small trees. It's been a process to get them built up.
This will be corn this year. Just planted so it matures later than the ag corn around here.
This is a summer mixed brassica plot. I'll till it under and replant the end of this month.
And then a few clover plots.
/ Next year food plot #7
Wow, they all look great.
Thanks a lot your food plot looks nice also
/ Next year food plot #10
Good timing for the cultipacker project. I look forward to see how it works.
/ Next year food plot #11
Wow! You have a lot of effort to get that piece in such good shape. All I have here are Ponderosa pine and the soil is ink black & quite acid. My garden grew as well as the weed did - once I added lime.
Thank oasis it was easy since I bought the brush hog.
2022 EZ-GO ELITE...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
