Another "smoothing lawn thread"
/ Another "smoothing lawn thread" #21
Hello LD1,
The fastest way to get the results you want are to mow closely and use a/overseeder dethatcher
and pick up the thatch and dirt clumps with a lawn sweeper since Mathews Lawn Genie Pick up
mowers are no longer made.
The dethatcher and an aerator will create great turf once the thatch dirt plugs are removed with a lawn sweeper.
Short of that a Land Pride or Caroni flail mower will solve all those issues for you.
Hello LD1,
Not sure I want to mow my lawn with my MX5100 flail. 5 acres and alot of things to mow around.
Not sure what you mean by mowing lower. I already mow about as low as I can, And still scalp in a few spots when one side drops into a derpession/rut or goes over a high spot.
Are you saying to use the lawn mower to intentionally scalp off the high spots?
/ Another "smoothing lawn thread" #23
If a top dresser adds fill in an even manner, won't I still be left with a rough lawn if I don't do something to smooth first?
Not at all concerned about a healthy weed free lawn. I hate yard work and mowing. I just hate dirt and mud more so that's the only thing keeping me from round uping the whole thing.
I'm only trying to make the dreaded task of mowing less unbearable and smooth things out.
I enjoy the fact that my unhealthy lawn only needs mowed once a week instead of 2-3 times like those that treat their lawns
PTO driven so you can lay it out where/when you want....Or, scoop of ______ fill low spots, smooth and seed. You either need a spotter to find the low spots or carry some marking flags when you cut and hit a bump :)
Marking Flags, Tape, Paint,
/ Another "smoothing lawn thread" #25
The Frontier power rake has a 250-275 RPM. Probably close to the Harley in speed but from the looks of it speed is the only comparison. It counter rotates but has a shield instead of a top roller.
/ Another "smoothing lawn thread" #26
I have learned over the years often many ways to reach same result. Our lawn was about 50% wooded area and we had trees cut and stumps ground. Long term mistake in smooth lawn as the stumps rot it needs work. But never would have been able to dig all probably so best option. Without knowing how un-level your lawn is will say the following: ours has some natural roll, has with old water run through it. The natural roll is not issue but the stump holes have been. It has been about 16 years since we cut the trees and for years have filled in rotting stump hole with top soil, shovel and steel tooth rake and it has done well for us. Need to do so even now and really thing this will be last time with the rain we got last fall and winter should be it. I am one of those who bought the Ferris due to rough lawn but then I have a medical issue that being shaken on lawn mower hurt (digestive system). The Ferris is so much better (not sure the model but full suspense) and I can run it wide open even with the few stumps holes we have. Mower I was using is Bush Hog their I think estate model but not the pro model (when I bought they had two last I look they have three models). The Ferris is much better than the Bush Hog as to comfort. Then my brothers Pro Bush Hog was smoother with the larger tires and longer wheel base. But the holes will be filled as soon I dig some top soil for them (excavator down right now). There is also the option of really bringing in dirt and leveling it I would say with box blade and really moving it over the ground a few times to fill in the low areas and take off high areas if need be. At least here our best lawn grass is slow to cover (at least two years but longer in most cases) and you do not want to go back to bare dirt.
/ Another "smoothing lawn thread" #27
Is there such a thing as harder and softer ground ? I probably cut ten acres around here, not all of it smooth and I never have an issue with getting bounced around. I cut ten acres for a customer last fall whos ZT was out of action. That ground seemed so hard, it just about killed me. Mind you, I did all of theirs in four hours and do mine a little here and there. I lowered the tire pressure and that helped a bit.
/ Another "smoothing lawn thread" #28
Was waiting on someone to say that. I haven't done much reading up on them, but how well do they actually work. I am sure it's a smooth ride, like my 4-wheeler would be. But cut quality? How does the deck act when I hit the bumps at 9mph that, on my scag, bounces the deck on the chains and almost throws me off the seat?
Surprisingly good. There is linkage that raises the deck when a wheel moves up.
SitePrep Demonstrates the Harley Rake - YouTube
1:45-2:00 mark
Just seems a whole lot faster than 250-275?? Maybe not.
My tiller is counter rotating, (reverse rotation), and runs 180RPM. With it being larger diameter, the blade tips are probably spinning faster than the harley rake.
The tiller dont do a good job. Almost hard to believe that a harley rake does a better job with knubs instead of tines. Especially spinning that slow.
/ Another "smoothing lawn thread" #30
Watching the video it does seem faster. This one has the nubs and some I've seen have the horizontal bars and one I seen has bars formed into a slight V shape (elongated V). All of them appear to do the same job. Maybe somebody will find time to count the RPM that ownes one.
If I were to build one I'd probably opt for the one roller with a adjustable shield instead of 2 rollers. Either way it seems like it would be a dusty ride especially on a skidsteer with no cab.
I saw one with bars too. Was gonna ask which works better? Bars would be alot easier to fabricate
/ Another "smoothing lawn thread" #32
Another thought for example: My flail mower gear box is 1:4 and the pulleys are on the drive and the cutter shaft are the same size so a little over 2000 rpm.
/ Another "smoothing lawn thread" #33
LD1,
What I have found works well in cases like you describe is to run my land plane grader scraper with 1/2" spacers on the bottom of the skids behind one tractor and use my backhoe to add pulverized top soil from behind. This add very little if any topsoil to the smooth areas but does add a layer to the holes and dips. In most cases the grass can grow back through the added layer. My blades on the lpgs are set flush so the added spacers allow the blades to ride just high enough to leave the existing grass in place.
You could build a box to do this if you don't have a lpgs.
Have been thinking about building a lpgs as well.
Got room any things on my wish list and to do list. But I'd imagine it would have to take some really fine pulverized dirt for the lpgs to be effective.
/ Another "smoothing lawn thread" #35
Have been thinking about building a logs as well.
Got room any things on my wish list and to do list. But I'd imagine it would have to take some really fine pulverized dirt for the logs to be effective.
I would not use big chunks and large dirt clods for this but it doesn't have to be like flour either. Dirt that you can blade down smooth is good enough. If your dirt is chunky then run over the dirt pile with a tiller to loosen it up.
I think I would high-center on either of my dirt piles, which are about 8' tall and 15-20' around.
/ Another "smoothing lawn thread" #37
I've used both and the carbide tipped nubs work better. Why do you think they no longer make the style IT has?
Matt
Before I try to build anything, I was thinking of expirementing with some different tine shapes with my tiller. And make some gauge wheels or gauge roller. Wish it was more than 54" though.
Cause I cannot seem to grasp how the harley rake would work better than my tiller? is it because the knubs are so short and close to the drum that instead of chewing up a ton of dirt, or "knifing in" and pulling up clumps, that the knobs dont really "knife" in but rather beat the dirt to a pulp?
Wouldnt take much to make a simple set of T shaped tines out of some 1/4" flat bar just to test the theory?? Then run some gauge wheels and test it out on some uneven areas.
/ Another "smoothing lawn thread" #39
Is a logs a fat fingered lpgs?
I'm used to dragging a 4x4x10 over fine soil to "even" it out and set seed, so I could see dragging a log, which would be easier to build than an lpgs.
Dang autocorrect on these phones.
Yes, I ment LPGS, I'll fix it
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A61574)
2017 Forest River...
2018 International LT Automatic Day Cab (A62613)
2018 International...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
