Ammunition
   / Ammunition #601
No, but my neighbors are atleast 200 ft away. (the .22). The .25 ACP is pretty dam loud, probably equal to a 9mm carbine (that range where I wear ear pro, but many dont).
Wouldn't subsonic .22LR be the same as .22 Shorts?
Maybe they would sound the same but they are not the same round.
TBS
   / Ammunition #602
TBS
Yeah, I realize that, but what I ment was the end result is the same, so rather than $0.25/rnd for Subsonic LR, you might be able to find some Shorts for cheaper. Not really sure how commonly available they are
   / Ammunition #603
   / Ammunition #604
There are several you tube videos shooting the various types of ammo. The CCI quiet's seem to work well and are accurate. Still pretty quiet, not as quiet as colibri, but much more accurate.
   / Ammunition #605
I can usually find shorts pretty easily. They last a long time for me.
I've never used the subsonic LR's. Just curious as to the noise they make.
TBS
   / Ammunition #607
TBS
Those CCI quiet Long Rifles seem to me on the you tube videos to be a bit quieter than regular .22 shorts.
   / Ammunition #608
just remember.. shorts won't feed or function in many autoloaders. bolts or single shots are usually fine. after shooting shorts, you will need to celan your chamber before shooting longs/lr.
   / Ammunition #609
Good point. I didn't think about cleaning the chamber.
   / Ammunition #610
Wife just got me a couple of boxes of Norma subsonic to use for late-night raccoon duty at the birdfeeder and garden. Part of what makes them sub-sonic is that they have a relatively heavy bullet - 40gr (lead, hollow point). They cycle my Ruger 10/22 just fine. They are not quite as quiet as I hoped - still a BIT of bang, but no crack. Louder than the .22 high-powered air rifle, but not a lot.
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A51039)
2019 Energreen EVO...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
