Front-End Loader Lost but Looking for Ford 2000 Front End Loader
/ Lost but Looking for Ford 2000 Front End Loader #1
DaleWol
Joplin, Montana
Ford 2000
Help! I have just purchased a Ford 2000 tractor. The serial number is 1004B so i think it is a 1962. It is a three cylinder. I have lots of light uses for a front end loader and am looking everywhere trying to find a used one with almost no luck. I found one made by Ford Dearborn Tractor with a serial number 1713. It came off of a Ford 600. Would it fit my tractor?
Is there a resource for such things which you, anyone, would recommend?
Any guidance or help you may give would be keenly appreciated.
Thanks,
DaleWol
/ Lost but Looking for Ford 2000 Front End Loader #2
If it is a three cylinder it will be a 65 or later tractor..Prior to that the thousand series were off shoots of the previous "01 " series in which the 601 series had a 4 cylinder lp,gas,134 ci or diesel 144ci 4 cylinder. 801 series had a 172 ci gas or diesel 4 cylinder..I believe in 65 they had the 201 ci 3 cylinder..If you had an early 60's 2000 ford the 600 loader would probably fit,,Your's being a three cylinder indicates a later model . Not sure if it would fit without modification,,
/ Lost but Looking for Ford 2000 Front End Loader #3
Thanks so much. It does appear to be 1971. With more careful research i think the 730 loader is the one to fit. So far i have not found one. Any suggestions?
Thanks so much. Your offer is a kind one. I appreciate this. However, i am going to try to find a 730 loader in the Western part of the US. Thanks. Any suggestions on finding one closer to Montana?
/ Lost but Looking for Ford 2000 Front End Loader #6
Another thing is other brands that have already been adapted for the Ford 2000/3000 series.
If you cant find one, give that number a call.. For a couple of hundred it might be worth the trip. 730's are hard to come by w/o buying the whole tractor.
KUBOTA L2246-65" PIN ON BUCKET (A62131)
KUBOTA L2246-65"...
Auger Bit (A61567)
Auger Bit (A61567)
UNUSED 250 GALLON FUEL TANK (A62130)
UNUSED 250 GALLON...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2013 International WorkStar 7400 Altec AM547 50ft Material Handling Bucket Truck (A61568)
2013 International...
