Calculating Cantilever Load Limits - Rule of Thumb?
   / Calculating Cantilever Load Limits - Rule of Thumb?
An engineering degree tells me to never stand on anything that is cantilevered!!
Odd, I thought I was standing on a cantilever every time I walk down the aisle of an airborne commercial airliner.
   / Calculating Cantilever Load Limits - Rule of Thumb? #12
Most sidewalks on truss bridges are cantilever
   / Calculating Cantilever Load Limits - Rule of Thumb? #13
Calculations could be made IF the fastener positions were known.
If there is but ONE fastener with a 700# Shear capacity, it can hold ZERO load cantilevered, the load will spin.
Think of a lever, the load, the fulcrum, and resistance. the spacing between the fulcrum and the other two points is the solution to the entire problem. (even if the fasteners are arrange vertically).
   / Calculating Cantilever Load Limits - Rule of Thumb? #14
Don't rely on the fasteners or wood grain just in upper cantilevered boards -- run additional brace boards on a 45 (or steeper) from the end of the cantilevered boards and back down to the structure. Will make a huge difference. I do that, just with 2x4 lumber and 20D nails holding things together, and have never run into issues.
   / Calculating Cantilever Load Limits - Rule of Thumb? #15
Sad degree you have there.
Look at alot of houses like split levels that have a little cantilever to the upper rooms. Or roof overhangs. Many many decks have cantilever.
   / Calculating Cantilever Load Limits - Rule of Thumb? #16
What's wrong with cantilevers? :)
Bruce
Good stuff!
This thread confirms my theory, simple minds over-simplify things and complex minds over-complicate things. True genius lies in finding the middle ground.
CalG - You are correct and good evaluation with limited information. One bolt would create a nice seesaw not scaffolding.
S219 - Your picture is almost exactly like my setup with the exception of the angled supports, I was going with a second board bolted directly under the extension but I believe your method would provide more stability even if the load bearing isn't a consideration. Taking the roofing out today and if it is not 100+ degrees I may do some testing.
Good discussion even if we all don't agree on the solution.
Here you are ladies, empirical evidence
250lbs suspended 28" from the fulcrum. Placed marks on the siding and no movement or snap-crackle-pop for over an hour. Granted this is a static load but considering the weight will be suspended between two points I do not see this failing. So what do the naysayers have to say? If the best you have, is you can never be too safe, please crawl back into your bomb shelter and await a safer world. The rest of us acknowledge living is not a risk free endeavor.
   / Calculating Cantilever Load Limits - Rule of Thumb? #19
I think you are just fine.
That's just a temporary platform for doing roofing correct?
If so, I'd probably just stand in my loader bucket and be done.:eek:
   / Calculating Cantilever Load Limits - Rule of Thumb? #20
Lift the bucket to the height of the ROPS and put the scaffold planks between Use a ladder to climb up. (But the ROPS works in a pinch.
70pc 8ft.x 3ft. Grey Metal Roof Panels (A55758)
70pc 8ft.x 3ft...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
New Kivel Skidloader Double High Back Bale Spear (A50775)
New Kivel...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 66"...
