Fuel filters and yet more Mahindra manual BS.
   / Fuel filters and yet more Mahindra manual BS. #1
dickfoster
Elite Member
Nevada City, CA
Mahindra 1538TLB
I just finished changing the fuel filters on my Mahindra 1538 gear tractor. The HSTs and 1533s should be the same as they all use the very same engine. I thought I'd try to prevent others from going through some of the aggravation I suffered by attempting to rely on the scant and erroneous info Mahindra provides in the operator's manual.
First of all some part numbers since Mahindra neglects to provide any in the operator's or service manuals.
There are two fuel filters, a pre filter and a main or final filter and they are different. The first filter or pre filter is a paper insert type with a removable bowl. The Mahindra part number is 001081778R93, this is a Mico 8461037407 also a NAPA 3993 should do the job.
The second or main filter is Mahindra part number E006018618D1 which is a Bosch F002H22025. You can pay Mahindra about twice the price and get the same filter or just buy the Bosch and get the same thing, your choice.
To start lift the hood and remove the left side engine access panel.
OK first of all the pre filter is NOT a spin on filter as the operator's manual says it is. If you try to spin that thing off with a lot of force you'll likely break something so don't don't do it or you'll pay. To get the filter can off, simply loosen the 13mm (1/2") drive bolt in the center in the top of the filter. It's a long bolt so I used a gear or ratchet wrench. As access is tight a socket won't fit and box end or open would you a take a lot of time which I don't have.
CAUTION when you loosen this filter you will drain however much fuel there is in the tank so be prepared. The book neglects to mention this tidbit too but after a couple of gallons had spilled into my drain pan I figured it out. LOL
There is a 10mm filter drain plug in the bottom of the filter can so you could slowly drain the fuel into a fuel can using this drain and some time depending on how much is in your tank. Or you could remove and plug the fuel input line from the tank to the filter. The input hose is held to the filter banjo fitting on the filter with a simple hose clamp. Some would clamp the hose but I never liked doing that to hoses. I chose to drain the tank into an oil change pan since I didn't have that much fuel in the tank.
Once you get the filter bowl off, swap out the paper filter element and reassemble the filter. You should get a new O ring filter gasket with the new filter so change it if it needs changing. You'd need to dig the old one out because it's stuffed up in there. With only 50 hours on my machine I saved the replacement O ring gasket for another day.
After you get the filter replaced, go ahead and get some fuel back into the tank so the filter will have time to saturate and fill up making your restart easier later on.
Now on to the fun of changing out the main or second filter. As is typical on these machines service access is very limited and tight. It's best to remove the left side splash guard to give you a little more room to work. Removing two 12mm drive bolts will get the splash guard out of your way pronto.
You could remove your loader but the tower would still be in the way so it probably won't benefit anything by removing your front loader.
Next you'll find a wiring looms blocking access to the filter so remove the reusable zip ties so you can move those out of your way.
Next remove the electrical plug on the water sensor that's on the bottom of the filter. Push the release latch and pull the connector down to disconnect it from the sensor.
I suggest leaving the water sensor screwed to the bottom of the filter for the moment so you don't pour fuel all over the starter and solenoid that's just below the filter. This IS a spin on filter so to get the filter loose I used a plumbing type strap wrench. I don't think you'd be able to get a regular filter wrench in there due to the limited space but I found I could work the strap around the the filter then use the wrench to get the filter loose enough so it would spin off. You should be able to work the old filter out of the confined space then dump the fuel into your drain pan.
Now you can unscrew the water sensor from the bottom of the filter. Careful to retain and not loose the O ring seal.
Now work the new filter into place and spin it on. Be sure to lube the gasket with some clean fuel first and snug it down, not too tight, snug will do as is typical for spin on filters.
Now you can screw the water sensor to the bottom of the filter and reconnect the electrical connector.
Next you need to bleed the air out of the new filter and prime the filter with fuel. To do this first open the bleed screw(the manual skips this step) it's a 10mm drive, that you'll find conveniently located on the top and to the rear of the filter adapter (yes I'm being facetious). Again I found a 10mm gearwrench would just fit in there. Don't remove the bleed screw, just back it out enough so air can escape.
Next, to prevent pouring fuel all over your starter, stuff some paper towels or rags back there to catch the fuel. Now push the primer cap down several times until fuel instead of air comes out of the bleeder and the primer stiffens up. Now snug down the bleed screw.
Check for leaks and try starting the tractor. The engine may start and run for a bit then encounter some trapped air and stop. Try priming it again and retry. If you trip the Check Engine light fantastic don't fret, panic or call your dealer, just keep at it till the tractor starts and runs run for awhile till the fuel system is fully primed with fuel. After a few starts the CE light will go out by itself or if you're the impatient type and have a scangauge you can reset the light and erase the error code using that.
After you're convinced that things are hunky dory, replace the zip ties you removed on the wiring loom, replace the splash guard, the engine access panel, slam the hood down and you're back to work.
BTW because Mahindra failed to provide the part numbers in the manuals as they should have it took me two round trips, to Yuba city and a lot of wasted time and gas to get it right. Hopefully this will make things a little easier for you.
Also a note on the water sensor. Mahindra put the water sensor up high on the second or main fuel filter where it doesn't do much good. Since the pre filter is obviously the low point in the system, this is where water will collect as water is heavier than fuel. The moisture sensor should really have been put there. By the time the thing goes off where it is now, the prefilter would be completely saturated and filled with water already. This is not rocket science nor is it hard to figure out. I'll probably get around to adding some sort of clear sediment bowl collector and shut valve to the input hose on my pre filter. That will make it easy to inspect and drain water plus allow me to shut off the fuel to make filter changes easier. I may even move the water sensor to that point or the pre filter since it would do more good there.
   / Fuel filters and yet more Mahindra manual BS. #2
Thanks for the write up. I really like your idea of a clear bowl down low. All new tractors should have one. The Mitsubishi engine our prior Max came with one, and this 2538 needs one as well. That setup allowed you to remove the bowl and it would actually shut off the flow of fuel while you dumped out any junk. Then when you screwed it back on it would refill the bowl and filter housing. I broke the max bowl off on some barbed wire one time and I think it was $50 to replace. Maybe there are cheaper ones.
   / Fuel filters and yet more Mahindra manual BS. #3
Great write up. Thanks for going to all the trouble and saving a lot of guys a lot of trouble.
Yeah that was my hope. If for nothing else the part numbers for the filters. The manual will lead you astray PDQ.
   / Fuel filters and yet more Mahindra manual BS. #5
Thanks for going to all the trouble!
No problem. If we all do the same it would help everybody. I can only do what I can for my model. Plus I'm a tractor greenhorn.
   / Fuel filters and yet more Mahindra manual BS. #7
On my 4540 there is a petcock valve at the bottom of the tank that will stop fuel flow so you can change your filters without loosing a tank of fuel.
If there's one on mine I haven't seen it and it's nowhere to be found and no mention of one in either manual but that's not saying anything either.
   / Fuel filters and yet more Mahindra manual BS. #9
Great article however when I changed the main fuel filter the electrical connector to the water sensor came away with a broken middle green wire very close to the actual connector! Any advice to re solder if possible or buy a new connector or do I have to buy the whole harness.
Any help greatly appreciated.
Thanks
   / Fuel filters and yet more Mahindra manual BS. #10
I'm amazed in how many people have changed their tractor fuel filters. People must be getting a lot of dirty fuel. I get my red off road from my farm Co-op and I got my tractor in 2007 and have 567 hours and still have the original filter. The manual says to change when you have problems.
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
Adams 8 Ton Weigh Hopper (A52128)
Adams 8 Ton Weigh...
