Big tex 45 SS
/ Big tex 45 SS #1
tjkubota93
Arlington, TN
Kubota bx1860
I'm wanting to get a 16' trailer to get lumber, sod, gravel and maybe haul my little bx 1860 with fel and woods bh. I have been looking around and am thinking of getting a big tex 45ss trailer.
G.V.W.R. 4,490#
Axle (2) 3,500# EZ Lube w/ (1) Elec. Brake
G.A.W.R. (Ea. Axle) 3,500#
Supension Multi-Leaf Spring w/ Equalizer
COUPLER 2” A-Frame
Tire ST205/75R-15 Load Range C SAFETY CHAINS 1/4” Grd. 30 w/Safety Latch Hook (2 ea)
Wheel 15" x 5"; White Spoke 5 on 5 Bolt Pattern
JACK 2,000# Top Wind (Bolted On)
Floor 2" Treated Pine or Douglas Fir* TONGUE 4” Channel
Lights D.O.T. Stop, Tail, Turn & Clearance TOP RAIL 2-3/8” Pipe Square Back Elec. Plug 7-Way RV FRAME 3” x 2” x 3/16” Angle
Finish (Prep) Steel is Cleaned to Ensure a Professional Smooth Finish. CROSSMEMBERS 3” x 2” x 3/16” Angle UPRIGHTS 15” Tall, 2” x 2” x 1/8” Angle Finish Superior Quality Finish is Applied for a Highly Decorative and Protective Finish.
FENDERS 9” x 72” Rolled Formed w/Back
• (4) Tie Down Loops Inside Bed
• EZ Lube Hubs
• Dexter Brand Axles
• Nev-R-Adjust Electric Brakes
• Cambered Axles
• 2-3/8” Pipe Top Rail
* Douglas Fir Available from Caldwell, ID
That's the specs. It's 77" wide.
Anyone think I should spring for a bigger one? I don't plan on my Silverado or wife's Tahoe being towed, but it's possible. I'm thinking keeping a bigger heavier trailer around just for that would just be a waste.
/ Big tex 45 SS #2
The finish (powder coat I'm nearly positive) on the Big Tex I owned was really bad. Significant flaking and rusting within a year. Otherwise, I was happy with the construction.
So only one axle has breaks on the trailer your looking at?
/ Big tex 45 SS
Yes. You can get 2 as an option, but I don't feel I need it. I'm pretty sure they spray them.
/ Big tex 45 SS #4
I have a big Tex 50LA in 18 feet for the tractor and misc hauler. It has almost the same specs as the one above. I have used it so much just because it's not overly big compared to my 10k trailer. It's been a great trailer.
/ Big tex 45 SS #5
Your state says you need brakes on both axles.
https://www.tn.gov/assets/entities/safety/attachments/TRAILERREQUIREMENTSTAG.pdf
DEPARTMENT OF SAFETY TENNESSEE HIGHWAY PATROL
TRAILER INSPECTION REQUIREMENTS BRAKES: (TCA 55-9-204) (FMCSR 393.42;393.43)
1.) Trailers with a gross weight of 3,000 lbs. or more are required to have brakes on ALL WHEELS.
2.) Trailer with a gross weight of 1,500 to 3,000 lbs. are required to have brakes on ONE axle.
3.) Trailers with a gross weight of less than 1,500 lbs. need NOT be equipped with brakes.
/ Big tex 45 SS #6
I have the 14' 50LA with ramp gate along with a 20' 12GP GN and both are good trailers. While the 50LA has the same specs it weighs more so I suspect there is more bracing.
/ Big tex 45 SS #7
I've got by with a 12 ft skid loader style trailer. It has 7,000 lb tandem axles which made it good for hauling loads of gravel just over 3 tons, from the quarry. I used some 2 x 12s as side boards and across the tail end (also a canvas tarp cover over the load). As a general purpose trailer it was just right for me, especially after I switched it from Surge brakes to Electric brakes (with a controller).
My B2620 just fit when the MMM and FEL was mounted. But Hey, I'm a homeowner that just does a few chores and not in a business.
Your BX should fit on a 16 ft with a FEL &/or a brush hog I believe. Some other aspects that you might consider could include property tax, license, inspections, and maneuverability especially for storage and parking. Usually, longer is better .........especially if later on you get a bigger tractor with attachments.
/ Big tex 45 SS #9
Thanks. By bh I meant back hoeView attachment 472043
...Roger that....
I think the fit would be just a bit longer, but not much for a backhoe. I guess measuring is the answer. Hey, I got one of those Cyclone Z-10 rakes too.........love it.
Now that probably wouldn't fit....when all hooked up.:)
/ Big tex 45 SS
Well I called the nearest dealer and asked how to order one, he never called back.
A freind was heading to texas and offered to pick one up for me, so i called the factory and left a message with the person I was directed to, and they never called back.
I want to buy a trailer and no one at big tex will sell me one.
A local Mahindra dealer sells Texas Bragg trailers, he is supposed to call when he gets a 16ft.
/ Big tex 45 SS #12
I had a similar situation with the local Big Tex dealer: Expressed interest, and the salesperson didn't seem interested in giving me the time of day. They need some sales training.
/ Big tex 45 SS #14
If it has 2 each 3500# axles, why would the GVWR only be 4490#? The empty trailer should weigh ~ 1500# - 1800# with the GTWR being ~ 7000#.
I avoided some trailers locally due to the GVWR (GTWR) being significantly less than 7000# with tandem 3500# axles. I just ordered a 16' Lawrimore utility trailer with tandem axles, brakes on both, mesh 12" sides, mounted spare tire, etc. The GTWR will be 7000#.
I also have a Lawrimore 20', 10.4k# equipment trailer purchased last fall that I like a lot. Pulls great and is constructed well.
/ Big tex 45 SS #15
It may be a tax or licensing adjustment.
In WA, a trailer over 3000 is required to have brakes, so there are many new trailers for sale, with a 3500lb axle and a 2990 GVW.
Bruce
/ Big tex 45 SS #16
Bruce
We see similar here in SC and I would understand that if all trailer manufacturers in a certain class were rated like that in a particular state, like all single axle trailers are in SC that I have seen. SC law stipulates that once a trailer hits 3001#, all wheels must have brakes. And there is not a tax difference in SC and trailers do not need to be registered/licensed. Another gotcha for any state is, if a trailer is rated for say, 5500# GTWR and weighs 1800#, its legal load capacity is only 3700#. So when I purchase a trailer, I make sure its GTWR/GVWR matches the combined axle ratings. Keeps me out of trouble in any circumstance, such as being liable in an accident not caused by myself when I am carrying a load close to trailer axle capacity/GTWR.
/ Big tex 45 SS
Thanks I called lawrimore. If my local guy doesn't come through or his Texas Bragg trailer is junk, I will go to lawrimore, it's 3 1/2 hrs away.
/ Big tex 45 SS
I finally bought a trailer. Texas Bragg 16' no brakes. I like that it's gray instead regular black.
/ Big tex 45 SS #19
How can you get by without brakes? What state are you in? Around here over 3K it must have brakes on one axle.
Chris
/ Big tex 45 SS
TN, I know a lot of people with very similar setups. I have never heard of police checking anything having to do with trailers. I'm not going out of state or out of town. So, I guess that's a crappy answer and I will get some responses about how irresponsible and dumb I am :(. Oh well.......
CASE 850M WT CRAWLER DOZER (A64277)
CASE 850M WT...
2007 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2007 Nissan...
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
