checking hyd fluid ?
/ checking hyd fluid ? #1
redka
Middle GA
JD 5403, is the hydraulic fluid level supposed to be checked(cold) before starting the tractor or after it's running and warmed up. The operator manual is not clear on that to me. Thanks
/ checking hyd fluid ? #3
Your dipstick should have a cold and a hot level. Low level for cold and as your tractor heats up the fluid will expand to the higher level.
/ checking hyd fluid ? #4
Not on a JD it doesn't. It should have a sight glass right beside the PTO shaft. Make sure the tractor is level front to back and side to side.
/ checking hyd fluid ? #5
I knew that some Deere's had sight glasses but did not think the 5403 was one of those models.
No HOT or COLD on the dipstick...just FULL. Don't think there is a sight glass but will check tomorrow.
/ checking hyd fluid ? #7
If you have a dipstick you should have a low and high mark. Low is for cold and high is for hot. Does it not have a knurled area that gives you a range?
/ checking hyd fluid ? #8
My 5303 has the high/low marks on the dip stick, i always check cold.
Ronnie
/ checking hyd fluid ? #9
Also another thing, have any attachment hydraulic cylinder retracted.
No sight glass. Dipstick has "ADD" and "FULL" mark.
Will check it cold. Thanks for the replies.
/ checking hyd fluid ? #12
I did not think a sight glass was used on that model...
That feature is more prevalent on smaller units...
Lot Seven (A3632137)
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2020 Ford F-53 Thor A.C.E 32.3 33.5ft Class A Mobile Home (A66738)
2020 Ford F-53...
20125 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
20125 WINSTON...
PALLET OF TOOLS (A68842)
PALLET OF TOOLS...
