Fescue Monoculture
/ Fescue Monoculture #1
JimHam
Duffield, VA
Kubota M8200DTC
I have 55 acres that is mostly grassland, former pasture and I have it enrolled in a conservation stewardship plan which means right now I cannot mow it until after Aug. 1. The grasses are fescue, orchard grass, switchgrass, lespedeza and some timothy. I mow about 2 acres around the barn and future house site and I get to it about three times a year because I live out of state right now. What I am seeing around the barnwhere I mow is that the fescue is taking over. I hope to start haying a good part of it when I retire and get settled there. My hobby is training and running labrador retrievers in hunt tests and field trials so I need a lot of open area. To maintain that open space I was going to have the hay cut off it. The problem is I do not want a fescue monoculture in my fields. I'm not a farmer but my grandfather and relatives are so I grew up working on the farm and helped put up a lot of hay but I don't know much about growing a good hay crop. I didn't think fescue was the best hay to feed. How do you folks that raise a lot of hay keep a diverse crop of different grasses for your hay? I want to combine wildlife cover and natural hay because right now I have a couple covies of quail on the property and want to provide a place for them too. Open to suggestions.
After doing some research I may have answered my own question. Kill the fescue and plant native prairie grasses; big bluestem, side oats grama, indiangrass, switchgrass. Only cut hay once a year in late june and cut 8 to 10 inches above ground. Burn the field in late april every third year. Don't use much, if any, nitrogen. problem solved!
Thanks for the info. I will check that out.
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
HOMEMADE 14' - 3 REEL TRAILER (A63276)
HOMEMADE 14' - 3...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
Used Landpride GR1525 Stump Grinder
Used Landpride...
