Electric clutch
/ Electric clutch #1
joebob
Manchester MI.
Case 530CK
Hi guys;
I have a J D L110 mower that I would like to install an electric clutch on, Possible? I see prices vary widely, which one?
Thanks in advance.
Joebob
/ Electric clutch #3
I don't know nothing about nothing,
...but I slept in a Holiday Inn last night & took a quick look at diagrams on John Deere parts website and .
It's hard to see what's going on across multiple diagrams, but presently does your PTO (mower on) lever engage pulleys on the deck that tighten the belt?
And when mower is off, does the belt just slips around the idler puller that's at the bottom of the engine?
So essentially your looking to replace item #18 on "power train/Belt Drives and Idlers page (P/N: GY20140) ? John Deere - Parts Catalog
Don't know how easy it would be to replace this with an electric. You want to make sure electric clutch matches the bottom motor shaft, that the bottom motor shaft is long enough. The tricky part is I think electric clutches require a fixed "rod" that doesn't spin extending down from the tractor so that the bottom part of the clutch assembly (where the wires connect to) doesn't spin. You have to accommodate this.
If you did add one, it would probably be easiest to leave your regular mower PTO in place and just leave it on rather than reworking the pulleys on the deck.
Why do you want to do this?
I miss the old pulley operated PTO of the Cub Cadet I had where you could ease the mower on instead of slamming it like electric clutch does (Although my mom's Honda mower has a pulley system on the deck that can't be eased, just reaches a certain point and slams in).
/ Electric clutch #4
Check your engine model for charging output. <10A might not keep the battery up with blades engaged. Engines meant for E-PTO typically provide 15A or more, so consider replacing a charging coil too if needed for the 'upgrade'.
I miss the 'old way' too, simpler and less scary when engaging blades. Belt length/tension requires much the same details/duties either way, so ...
/ Electric clutch
Many thanks guys for the responses. My J D is as Coby describes. Sounds like more tan I'm willing to mess with. In my younger days, I would have done it rite away, but not able to do much any more. I wanted to look into it cuz wife has a hard time moving the lever. Boy, don't ever get old, nomsayin?
d
a
SHOPBUILT S/A DOG BOX TRAILER (A63745)
SHOPBUILT S/A DOG...
2021 Kubota SVL97-2 (A62180)
2021 Kubota...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2015 Mack CHU613 Semi (A62180)
2015 Mack CHU613...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
