ford 2120 hss clutch slipping?
/ ford 2120 hss clutch slipping? #1
seeds and spores
marquette, mi
ford 2120 hss
trying to determine if indeed my clutch disc is the problem. changed hydraulic filter and fluid. clutch slips in forward gears (engine revs, but no power). reverse seems unaffected which is why i question the diagnosis? I have a ford 2120 hss mode command.
/ ford 2120 hss clutch slipping? #2
Doesn't sound like clutch. Sure you used the right fluid?
I own one if these rigs, love it, and fear the hyd clutch packs a little.
Jim
Jim
Thanks for the reply. I used tractor hydraulic fluid. When it is losing power, engine revved, you can feel it catch a little accompanied by a noise.
Not sure if this means anything, but PTO clutch seems to work fine as well, ran it under load last night. Just trying to figure out how this clutch works in there. Thanks.
/ ford 2120 hss clutch slipping? #5
I think it's just a single disc dry clutch, no separate pto clutch. I looked it up as 10.2" dry for the 12x12 shuttle trans. The non-Hydraulic-shuttle 12x4 rigs use a two plate clutch.
Jim
/ ford 2120 hss clutch slipping? #6
Here's the troubleshooting page from the transmission owner's manual. I don't think it will help much but maybe. How's things going?
Jim
  • EHSS troubleshooting.pdf
(1) Blackstone-OTR 39x15-22.5 Foam Filled Tire w/ Rim (A60463)
(1) Blackstone-OTR...
Mini excavator set attachment (A61567)
Mini excavator set...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
2025 AGT QHT500FL (A60463)
2025 AGT QHT500FL...
Kubota U55-4 (A57148)
