If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #361
I dont know if i am asking this in the right thread as i am new to the site, but i am having a problem with my 05 toolcat 5600 B series having a lack of power. i have to have it at half throttle for the machine to move smoothy otherwise it hesitates to move, it also seems to have more of a wineing sound coming from the drive system. The machine also struggles to pick any dirt up from a pile, if you could help me out with this problem that would be awesome thanks for taking the time to read
   / If you have Toolcat questions, ask them here... #362
How is the engine running? Is it idling smoothly? Is it laboring and or hard to start? :confused3:
   / If you have Toolcat questions, ask them here... #363
I'm assuming you have changed the fluid and filters for the hydraulics and transmission??
   / If you have Toolcat questions, ask them here... #364
A filter really would not affect a Bobcat in the manner discribed. Bobcat hyd systems do the cooling and filtering at the end of the line. There is no suction filter or screen. Low fluid could be cause. :thumbsup:
   / If you have Toolcat questions, ask them here... #365
the engine and everything runs fine no laboring and idles great
   / If you have Toolcat questions, ask them here... #366
where is the tranny filter located
   / If you have Toolcat questions, ask them here... #368
If not in drive, does boom work okay? How long after starting and running does problem occur?
BTW, welcome and you are in the right place. These guys are great.
   / If you have Toolcat questions, ask them here... #369
The problem occurs right away, as soon as you start using the machine. The boom works great when its not in drive, but as soon as you go to put it under a load the machine has no power to drive into the pile or to lift the boom once you finally get the bucket into the pile
   / If you have Toolcat questions, ask them here... #370
Thats because, I'm betting, one of your drive motors is bad. Its leaking internally and dumping your charge pressure. :eek:
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2017 Caterpillar 249D Compact Track Loader Skid Steer (A55851)
2017 Caterpillar...
JOHN DEERE 333G SKID STEER (A52707)
JOHN DEERE 333G...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2006 Vermeer BC1000XL Towable Brush Chipper (A55851)
2006 Vermeer...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
