JD 2210 mmm bell crank
   / JD 2210 mmm bell crank #1
Ron123
Benton, MO.
John Deere 2210
I have a John Deere 2210 tractor that I bought in 2005 with a 62C Mid-Mount Mower. I would like to use the mower again. I used the mower the first year for about 10 hours and then put it in my garage where it has been ever since. The question that I have is about the bell crank, the one I have on my tractor I think is bent. If anyone has a 2210 or 2305 tractor with an mmm would you please look at the pictures that I have taken and tell me if it is right.
   / JD 2210 mmm bell crank #2
I have a 2010 model 2305, at first sight - looks the same. I added a. = 2x2x1/4. Strap on mine before I put on the iMatch. Certain implements I had were not wide enough for the arm to catch and lift the deck. I'll look in the afternoon an post a pic if no one else has gotten back to you.
Bill
   / JD 2210 mmm bell crank #3
   / JD 2210 mmm bell crank #4
Looks to me like a situation where the mower deck ran out of travel before the lift arms did. Maybe you can recall the song by the Bobby Fuller 4: "I fought the Lawn and the Lawn won."
I think the arm on the bell crank is bent up. Tomorrow I will raise the three point arms up and look if it touches the bell crank and will take some pictures if I have the time. I would like to thank all of the posts above for their help.
   / JD 2210 mmm bell crank #6
Let me know if you need any more pics of my 2305 at a specific angle.
Thanks for the offer. Look at these two pictures for me and let me know what you think. The 2nd picture is with the 3 point arm all the way up and the arm is just barely touching the bell crankDSCN0143.JPGDSCN0144.JPG
   / JD 2210 mmm bell crank #8
My 2305 came with a travel bar. I took it off when I first bought the tractor and put on a TSC county line box blade. I jumped on the first time and was supposed that the deck wouldn't lift up. It took me a few mins to figure out the 3 point arms were not spread far enough for the arm to catch and make it lift. I now have the iMatch and have fabricated all my rear implements to fit it. With all that said, I noticed your turn buckles are screwed in and a bungee pulling the arms together. Could it be that it's as simple as spreading the arms to make it look normal and function ? Not intended to insult: just hard to help diagnose with words and pics. I'm a hands on .... Lastly- I think from the pics, every thing looks normal- surprised no expert has chimed in to help you. Let me know what you come up with. Bill
   / JD 2210 mmm bell crank #9
Seems the "expert" has just chimed in... and found the problem.. ;)
Or, have the bracket (bell crank) heated and bent to accommodate the lift arms where they are now pulled together.
(might have been bent out and just needs bending back)
   / JD 2210 mmm bell crank #10
I really don't think so, from what I could see in the pic, I just went to mine, took off the iMatch and screwed the turnbuckle in to match what I could see in your pic's. They looked the same. I'm guessing your left ( back facing forward ) arm just needs adjusted out and a bar or implement added to keep both arms spread apart. Expert ? Hmm need to show that one to the wife- she will say otherwise 😔
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2018 INTERNATIONAL...
2010 INTERNATIONAL DURASTAR 4300 CARGO TRUCK (A50854)
2010 INTERNATIONAL...
Unused Delta Crash...
