RATCHET RAKE TODAY // FEL Bucket Attachment
/ RATCHET RAKE TODAY // FEL Bucket Attachment #21
Maybe he don't have a camera..Calling him a liar is going a bit far.
Please quote where I called him a liar. If a police office ask for identification to prove who you are would you call him a liar?
I am asking for proof, because there are hundreds of ratchet rake owners here and not one has reported wearing the teeth down. The fact he has not responded does look like he misspoke.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #22
Maybe saying Liar is a bit far so lets say he is unbelieveable unless he shows proof?
/ RATCHET RAKE TODAY // FEL Bucket Attachment #23
I just opened this thread again after my post. .. I will snap a pic later today if I have time. My Kubota has less than 200 hrs. It is not used as often as my Skidsteer due to the fact he skid is just faster at doing the chores I need done. The tractor is used often to grade my driveway and road which is a mix of processed gravel and crushed bluestone. That combo of materials devoured the teeth on the rake in very short order.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #24
Pics as promised. This RR has been used less than a dozen times.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #25
what did you do drag it from Boston to Fla a dozen times?
/ RATCHET RAKE TODAY // FEL Bucket Attachment #26
Nope, my gravel/ crushed bluestone driveway. ...which is being paved this week.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #27
Paving your driveway will wear out the Ratchet Rake even faster. Or it may put a square edge back on the teeth.
Bruce
/ RATCHET RAKE TODAY // FEL Bucket Attachment #28
I've done my gravel driveway many times and all kinds of other work, with just roughed up paint as the result. You must have gotten a bad one somehow.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #31
You may want to try contacting them directly. If they stand behind their product, they may replace or give you some kind of compensation. It should not have worn down like that.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #32
View attachment 471641View attachment 471642
Thanks Tomtint, taking a measurement from your pic and comparing it to mine it looks like you have worn off 1/2" from the small (side) tines. On mine the base is 1.5" and the length of the small tine is 2". Your base and length of tine appear to be the same.
The combination of rock material on your road appears to have the same effect as a grinding stone.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #33
I'm guessing that there is maybe 1".. No more that 1 1/4" left on the bottom teeth. I'm having a friend who is a welder by trade, cut off the mounts so I can flip it and have the larger teeth point down. As I said earlier, it was a decent piece of equipment for the money, obviously it has its limitations. I would classify it as a bit above average for homeowner use. Definitely not commercial grade.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #36
Our crushed blue stone is nothing special. It's used all the time under walkways as a base material and also as filler material between landscape pavers, bricks, and stepping stones. It's relatively fine in size which allows it to compact well and also drop down between walkway materials. Apparently, it must be abrasive as well.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #37
Wow! Are you sure you don't have blue diamonds? That is unbelievable wear. Though I didn't voice it, I confess to doubting your word. Therefore, my apologies.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #38
I doubted too, but seeing is believing.
Tomtint, did you buy the 72'' rake or a shorter one? The 72'' should have 5/8'' thick steel and the shorter ones 1/2'' thick.
/ RATCHET RAKE TODAY // FEL Bucket Attachment #39
It's a 72"
/ RATCHET RAKE TODAY // FEL Bucket Attachment #40
Did you contact them to see what they thought? I'd bet the poor thing didn't get any heat treatment during mfg.
Jim
Kubota L3130 (A53317)
2019 Ford Expedition MAX 4x4 SUV (A59231)
2019 Ford...
2007 Ford F-250 4x4 Crew Cab 7ft. Flatbed Truck (A59230)
2007 Ford F-250...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
Rhino DB150 (A57148)
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
