2510H Zerk fitting
/ 2510H Zerk fitting #1
PNWKioti
Pacfic Northwest
Kioti 2510H
Hello fellow Kioti owners. Here's a little introduction. I've been lurking around for a few months, reading threads, researching my tractor purchase. In March, I pulled the trigger on a new 2510 HST FEL W/toothbar and a boxblade. This is my first tractor and I'm having a blast learning to master the art of using the FEL (I do believe its an art). I have 2.5 acres partially cleared with a gravel drive to maintain. So far, I've used the tractor to grade my drive (another art I'm going to need work on), and cleared a 45x35 spot for my garden. I dug out a lot of 3"-6" stumps as well as 3 in the 12-18" range...I think this would have been impossible without the toothbar btw.
Now the reason for my post. When I was doing my 10hr maintenance I found a few grease fitting that would not accept any grease. No biggy, I just removed a good one, installed it, greased the fitting and reinstalled the old fitting once it was lubed up. Problem is I cant find replacements at any of my local auto parts stores. Does anyone know the thread size of these Zerk fittings? I brought one with me to the store to match up and was told it was a 10mmx1, got home and it was a no go, too big. 8mm is definitely too small. I put a caliper on the org one and the 10mm, and there is about a .020 difference. Any help would be appreciated. I'm also having an issue shifting between high and low...ill save that for its own thread once I get a better idea what's happening.
Also, on a side note, I have a workshop manual. For those of you that don't and have questions that can be answered in the manual, feel free to ask!
/ 2510H Zerk fitting #2
Look here.
It is an odball (BSP) size. This is an old and recurring subject. Dealer is your best bet if one is nearby. Otherwise look on the net.
/ 2510H Zerk fitting #3
Welcome and congrats on the new tractor! You will love it. I have about 120 hrs on mine and daydream all the time at work about stuff I could be doing with it or upgrades lol. I'm assuming your talking about the grease fittings on the loader? I also have the same issue with switching from high and low, sometimes it doesn't want to go in gear. I usually roll forward a little and it will shift fine. Also, what type of toothbar do you have? Need pics!
/ 2510H Zerk fitting #4
I've got a couple zerks that wouldn't take grease on our CK35 last time I gave it the once over so I bought us one of these bad boys.
The Zerk Zapper Grease Fitting Tool - Made in the USA
The theory on how it works and reviews I found on other forums were pretty good and I figure we are forever getting a clogged fitting on something between tractors, mowers, and implements so why not?
My first "chore" this weekend is going to be another top to bottom greasing of the tractor and disk harrow so I'll most likely get to give this little guy a chance soon.
/ 2510H Zerk fitting #5
I've got a couple zerks that wouldn't take grease ...
I had a similar problem with a couple loader zerks when I first got my (used) tractor. I removed the offending fitting and cleaned it out from the thread end with a pick (like dental tools). It looked like it was plugged with dry grease and some kind of fibrous stuff. After cleaning, I verified that grease would pass and reinstalled. No problems since.
Oh yeah, I did this only after finding that none of my stock of zerks would fit.
1/8" BSP....never heard of such a thing. Thanks for the knowledge transfer. Ill order some up online, my dealer is over an hour away.
southern Al- Im going away for the holiday weekend, ill post some picks of the toothbar when I get back. Not sure on the manufacture, I ordered it through the dealer and there are no makers mark on it. HUGE difference in digging ability, especially if your trying to dig out stumps.
Here is a pic of the toothbar as requested:
/ 2510H Zerk fitting #8
I really like that. Anyway you can find out who makes it? Is that a 5 ft. boxblade?
/ 2510H Zerk fitting #9
For the $35 for the zapper, you could have bought a drill bit, tap and a whole box of zerks and just remove the ******* sized one, drill out and tap for a standard USA zerk size and then problem solved for present and future needs.
/ 2510H Zerk fitting #10
True, but ...
Just last week I finally got my motorcycle back together after breaking the bolt that holds the seat on - and then breaking the tap off in the nut after I drilled out the old bolt. :mad:
and that one was in a very easy to get to right on top kind of place, imagine the zerk on the center of the front axle of the CK & what a PITA it would be to work under there if I screwed something up.
Needless to say me and taps don't get along so I'll pass.
Besides if I went to the trouble of taking the zerk out - I could just heat it with a torch, clean it, and put it back.
And FWIW - I did use the zapper on a couple stubborn zerks on the FEL. Loaded it with Hydraulic Fluid, couple taps with the hammer, and presto - greasing again.
No, sorry, its just a generic toothbar. They're all over eBay. And yes, 5' Tarter Boxblade out back.
I just ordered some 1/8 BSP grease fitting from Newegg.com of all places. Pretty good price too. 45 degree offset 10 pack was $7.53, straight 10 pack was only $3.78. Ill list the item number if anyone else is interested.
45 degree Item#: 9SIA5D52R22341
Straight Item#: 9SIA5D52PH3711
/ 2510H Zerk fitting #13
New egg? Wow, didnt even think about them for grease fittings. Who knew? Good find if they work. Can you verify these are "plug N Play"?
They should be arriving via UPS on Wed. Ill give conformation they are "plug and play" Thursday/Friday...stay tuned.
Just to report back...the zerks from newegg.com are "plug and play". The only difference I see is the factory zerks take a 10mm socket, the newegg zerks take a 11mm socket. Hope this helps anyone looking for a affordable replacement for the factory 1/8" BSP grease fittings.
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
1999 FREIGHTLINER FLD70 ROLLBACK (A65643)
1999 FREIGHTLINER...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
