Can two hydraulic cylinders of two different sizes, be plumbed together?
   / Can two hydraulic cylinders of two different sizes, be plumbed together?
Functioning something like this, mechanically?
Bruce
Yes! Thank you for taking the time to provide that..... I am not skilled at drawing, and worse, posting pics.
Thanks.
The function is not for pushing, but for pulling the larger cylinder will have far less leverage, and the smaller more so there shouldn't be any issues with over stressing the cylinders.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #12
Thanks.
Sounds more like this diagram:
Bruce
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #14
Something to consider is to arrange the leverages to not use the cylinders together.
The boom will be hardest to raise when more horizontal. This is when it would be an advantage to use the larger cylinder alone. As the boom reaches, say, 45 degrees, the large cylinder is at the end of the stroke, and then the smaller cylinder continues the lift.
Bruce
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #15
I do not see the need for 2 cylinders in that situation , just tilt that post back and make it rigid. When the angles change so does the leverage. To use them like that you need separate valve control or you have a priority situation where you actually may go down instead of up because of load changes. Backhoes for example have different pressure relief settings for different cylinders because one may over stress another and break a hose or worse.
Bruce
Yes the smaller cylinder will be used with 20 degrees either side of vertical, and the larger from 20 degrees to beyond horizontal.
so hopefully because the bottom of the stroke will be beyond horizontal, and the smaller will have far more leverage, there won't be an issue.
I need 17" of total stroke, but don't have enough room to install a cylinder with that kind of retracted length. Otherwise I would definitely prefer one cylinder. The smaller cylinder will have priority as it will leverage almost 3 time the push/pull poundage as the larger cylinder.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #18
If you don't need down force, maybe a stroke-doubler cable and pulley system would work.
Bruce
Bruce
If I was purely lifting that would work, but the needed movement is a radial curl, and in a very compact area.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #20
What about when retacting the cylinders? Could the larger one pull the rod or damage the packing of the smaller one?
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
