Grapple
/ Grapple #11
Depending on where your at in northern TN, Wells tractor in greenville has the 48" W.R. Long Loader Open Bottom Grapple 2 for Compact Tractors in stock that you can check out. I think it weighs about 350lb.
/ Grapple
Wells is just down the road about 15 miles from me. I stopped in there when I was shopping for a tractor, wasn't to good of an experience. They didn't seem to interested in dealing with a small tractor purchase like mine.
I will stop in there and see what they have once I get to town next week. 350Lbs would work, not to heavy. The E.A. grapple looked good at only 275lbs, would mean a bigger log for milling without fighting the limits of my FEL.
/ Grapple #13
Yeah I heard things went to crap when Wells got deployed. Hes back now so things should be getting better down there.
/ Grapple #14
WR Long is one of the granddaddy grapple companies for CUTs. Very high quality but expensive as they don't sell direct so dealer markup cuts into value. They also don't innovate the way EA does.
Bottom line is that virtually any 48" single lid grapple of decent quality is going to meet the grappling needs of 95+% of CUT owners. Virtually nobody who buys one ends up "upgrading" and almost all are delighted with performance and longevity. Spend more for heavier, wider or fancier metal grapple if you must but the basic 48 does the job just fine.
/ Grapple #15
Here is my 50 inch EA single lid. It weighs about 275 lbs. Works for me. You can see how I control the grapple lid with the remote lever on my tractor is conveniently located just forward of the loader joystick. Also don't forget if you do run your grapple from a rear remote you will need to have quick disconnects in the middle of your tractor where the loader quick connects are so that you can take your loader off easily without taking off the tye-wraps on your loader arms of your new run of hydraulic hoses.
DSCF0554.JPGDSCF0550.JPGDSCF0551.JPGDSCF0528.JPGDSCF0512.JPGin use.jpgDSCF0514.JPG
/ Grapple #16
I agree with most everything James says except for the need to have a set of quick connectors in the middle of the tractor. That is exactly what I had on my CK20. In three years I used them precisely zero times. Most of us don't remove the FEL much at all. So long as you secure the hoses with zip ties under the tractor, it takes only two minutes to release them and perhaps five more to replace them if you ever do remove the FEL. It almost doubles the hose cost to put the split system in and I just found it unnecessary.
/ Grapple #17
I will admit I have only taken the loader off a couple of times since putting in the quick connects on the middle, but It still gives you the option. I hate to cut tye-wraps and reroute hoses. And mainly I mention it because I would not want some poor fella to go "dope! (channelling Homer Simpson)" Because the thought of removing the loader did not occur to him.
So of course, do what suits you best. And if that is a simple diverter up on the loader frame, and using the curl/dump function of your loader joystick instead of a rear remote which you may not have, well that is fine too.
Or go full out and set up the 3rd function. It is all whatever how you want to roll.
/ Grapple
I already have an extra rear remote, so there is no plan to add cost to this. Not sure if I will make a connection in the middle or not, most likely no at the beginning, but later on when funds are available I will.
/ Grapple #19
Here are a couple of places to look for hoses.. Use a garden hose or piece of 1/2 inch rope to get your lengths. I got mine from surplus center
Made-To-Order Hydraulic Hose Assemblies
Surplus Center
/ Grapple #20
Use a garden hose to measure the length of hydraulic hose you need to go from rear remote under operator station up FEL post and down to torque tube. Add a foot or so and make gentle turns. Order 3/8" hoses (more flexible and plenty of flow for grapple) and get 90 degree adapters for the rear so you don't need a lot of vulnerable hose looping back. 1/2" quick connects are kinda standard so you'll need step up adapters. You'll need 1/2" for the rear with step up too. It sounds complicated but is actually pretty easy. A local hydraulic shop can make it up in half an hour while you wait but if you order all parts from Surplus Supply you'll save about 50%. .
KUBOTA RTV900 UTV (A62130)
KUBOTA RTV900 UTV...
2012 ISUZU NPR FLAT BED 4X2 TRUCK WITH PUMP SYSTEM (A59906)
2012 ISUZU NPR...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
(INOP) 1996 FORD F150 SIN CAB TRUCK (A59823)
(INOP) 1996 FORD...
Attention (A57148)
Attention (A57148)
43023 (A59228)
43023 (A59228)
