BX2230 only runs in start position
   / BX2230 only runs in start position #1
audiocontr
East Aurora NY
Kubota BX2230, Ford 8n. Ford 861, Kioti CK4010 SE, Ford 4000 industrial with backhoe
Went to start the tractor last week and it immediately shuts off once i back off the ignition from START to RUN. I read the ignition is the culprit, but the condition continues even after replacing the ignition.
I've checked all fuses next to the battery. Is there another one hidden somewhere?
The mower will run if i remove the solenoid, and shut down when i press the solenoid back into place. Is there any way to check the solenoid?
   / BX2230 only runs in start position #2
If the pto is engaged or the HST/shuttle is not exactly in neutral and you aren't in the seat this may happen, check seat switch plus others first. Also check for power at solenoid terminals when cranking as some solenoids need power to shut down, others need power to to have engine running. Solenoid resistance should be fairly low 0~12 ohms I would expect.
   / BX2230 only runs in start position #3
Most shut off solenoids I have worked with on trucks are actually 2 solenoids in one. the first pulls the plunger back when you turn the key to start and the second holds it back while in the run position.I would guess that the solenoids on our Kubota's is the same The second is the part that usually fails as it is energized all the time the engine is running. Check (with a test light or multimeter) to see if you have current to one of the wires while the key is in the run position. If you have then the solenoid is probably shot.
I decided to put my CD manual in and see what it says. The black wire is ground, the white wire is for the pull in which you know is working since it starts when the key is in the start position. and the red wire is for the hold portion of the solenoid.
Pull the solenoid, hook a ground to the black wire, hook pos to the red wire, push the plunger in. If it does not stay in the solenoid is shot.
   / BX2230 only runs in start position #4
What, engine is on your BX2230? My BX2230 has the D902 and has a keystop solenoid, that is only ENERGIZED TO STOP the engine it does not require voltage to run.
Check the keystop relay timer to see if it is working properly, the timer relay kicks in when the key is turned off or the safety switch circuit is broken.
David
While I agree with your observation, in the case of my tractor, the unit will not start at all if the PTO is engaged, or not in neutral. In this case, it starts just fine. Shuts off immediately after.
Thank you. I will use this to determine if the solenoid is faulty
David
Uncertain of engine. I will look. Can you suggest the proper method to check the relay? Where is the relay?
   / BX2230 only runs in start position #8
Check the solenoid fuse first. If it is blown or not engaged the solenoid will act as you described.
   / BX2230 only runs in start position #9
If the solenoid fuse is blown then the tractor would not be shutting down as soon as the key is released, it is a STOP solenoid not a fuel solenoid.
David
   / BX2230 only runs in start position #10
David
Yes it is a stop solenoid but there is still fuel in the line that gets sucked in and lets the engine fire.
I have had this issue before. I would start with the easy trouble shooting first.
Its one of the fuses next to the battery, behind the ignition correct? In that case, all fuses are good
   / BX2230 only runs in start position #12
Ok, next loose or broken wires. You can ohm the solenoid to see if it is bad.
Looks like its the solenoid. After review, i see the back of the solenoid melted and popped.
   / BX2230 only runs in start position #15
The solenoid should not be melted, it is only energized when shutting down engine and then is released.
David
   / BX2230 only runs in start position #16
I had an issue with a "leaky" timer relay. It was sending a small amount of voltage to the stop solenoid all the time eventually causing the solenoid to freeze up. Ended up replacing both the relay and the solenoid to solve my shutdown problem.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
