Damaged block installing block heater L5240
   / Damaged block installing block heater L5240
No, I was making a funny. Meaning that I should have taken the engine out to install the block heater the first time. It would have been much easier and I wouldn't have had anything in my way!
   / Damaged block installing block heater L5240 #413
Any guesses on how many man-hours you'll have in you'll "install block heater" job. That way when some new poster here asks....
   / Damaged block installing block heater L5240 #414
That's just not right. :)
It might not be right, but it sure is funny!
Probably somewhere in the neighborhood of 80 hrs. Not counting the 4 trips to the machine shop, parts runs, hours of research.
Had a good night. I just shut the lights off at 11:00.
Valves adjusted.
Hydraulic pump installed.
Fuel filter and lines installed
Wiring harness re-installed including starter, alternator.
Fan installed.
Brake linkages re-installed.
Coolant filled (no leaks).
Battery charged.
2 gallons of Fuel in tank.
Instrument panel re-installed. Turned the key to "run", all pre-start lights work.
Tomorrow, I just need to install the hydraulic suction hose, top off the Super UDT, install oil & filter and we can start her up.
I'll be sure to video it.
   / Damaged block installing block heater L5240 #416
Valves adjusted.
Fan installed.
Battery charged.
I've been following along even though I haven't posted. Hope all works well.:thumbsup:
   / Damaged block installing block heater L5240 #417
ROFLMAO!!
And what would the cost of the heater be if you added up all the parts, shipping, tax and ALL the labor at $125/ hour?
   / Damaged block installing block heater L5240 #418
ROFLMAO!!
don't forget the lost use hours of the machine has value too..
Well, I'd like to say that I have the tractor running, but my uncle was not available last night. I am ready to turn the key. So it's looking like Monday or Tuesday night.
I filled the filter with oil, squirted oil down the oil filter line also. Since I wasn't going to start it, I worked on a new switch for the utility lights, tightening the floor "deck" bolts. I hate to go any further before we start it up. I figure after it's running, I have another 2 hours of mounting the instrument column covers, floor mat, loader mounts, hood, grill, etc... Was so hoping to do that today.
Oh well.. I've waited this long.
By the way, I forgot to mention, we also replaced the output shaft for the front driveshaft on Tuesday night. I was dreading it and almost skipped it, but I knew I would kick myself later. I am hopeful that the slow drips are gone now that all three seals to the clutch housing are new. If I am successful with my entire project, It will still have been cheaper than paying a dealer to replace this one seal.
1994 KENWORTH T800 (A58214)
1994 KENWORTH T800...
2020 Bobcat T595 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T595...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A55315)
2017 Cadillac...
2007 JOHN DEERE 710J BACKHOE (A52707)
2007 JOHN DEERE...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
