How To Repair Bent Lines?
/ How To Repair Bent Lines? #1
South Louisiana
Kubota L4600 4WD w/loader
I have some metal lines for power steering on an old tractor that were bent and now leaking. What is the best way to repair this without replacing the whole metal line?
/ How To Repair Bent Lines? #2
With the rubber lines right there anyway, Cut back to good straight metal. Put on a flare fitting if your equipped, or a compression fitting if not.
(Doing either RIGHT is the most important part. PS runs around 1000psi rough guess)
Select fittings to get everything to hook back together. I'm saying less than $60 in parts, you might wnt a new hose assembly depending on many things. Oh, and make up a support bracket that keeps those lines out of the way ;-0
/ How To Repair Bent Lines? #3
Agreed, go flexible to hard with better placement and geometry.
/ How To Repair Bent Lines? #4
I have used compression fitting to fix PS issues like that a few times. A 10$ tubing bender from Harbor freight, 6 feet off steel line and 4 compression fittings will be less than 40$. The cheap flaring tools from HF are not worth it.
/ How To Repair Bent Lines? #5
Remember, you can get legit compression connectors for real hyd applications.. Ie, good for anything 1 or 2 wire is good for... Not just low pressure Hyds.
/ How To Repair Bent Lines? #6
Clean up the spot where it leaks, and braze it...
SR
/ How To Repair Bent Lines? #7
Replace the metal lines with hydraulic hose.
/ How To Repair Bent Lines? #8
EAs stated, attach the flex hose to a good portion of the hard line and fabricate a proper bracket.
On the fittings go with proper hydraulic ones as stated. They will cost more.
/ How To Repair Bent Lines? #9
If I was doing it, and wanted to keep it looking original I would get some new tube, bend it using a tube bender, and cut the old line flare it, and replace the bottom 90 or s bend on the lines using the JIC fitting like on the tractor all ready,
for fast and dirty fix take out the torch and braze them up, and keep on going,
the last way would be to get some longer hoses, and cut off the bent metal reflare and use longer rubber lines,
some depends on skil and tools, but if tool short take the lines off and take to a shop that has the tools and have them reflare and bend the parts,
/ How To Repair Bent Lines? #10
SR
looks like at least one of the lines is nearly bent in half.. that's a bad flow restriction... needs to be cut out.
well, if there were a prize to win, hosspuller would get it, lol.
After taking my line to a hydraulic repair shop, they could not fix it due to the type of connectors and suggested I do the hydraulic hose until I could find someone who could repair it. Well, I put the hydraulic hose on and it fits and looks good, just gonna go with that. It is on an older tractor so functionality is the main goal here.
/ How To Repair Bent Lines? #13
As you can see there are many ways to skin a cat. You got it fixed and you are happy. You couldn't ask for more.!!
gg
/ How To Repair Bent Lines? #14
Wait.. I dont understand... They couldn't fix the metal lines because they didn't have the ends it needed, but they did have the ends for hydraulic? Sounds fishy..
While whole hose replacement is fine, sectioned should have been possible.. Not surprising they wanted to sell you what was on hand I guess.
This is one of the ends of the tubing. Guy at repair shop said they don't have anyway to duplicate that.
/ How To Repair Bent Lines? #16
sounds like it is a 'hose making shop' and not a hyd shop.
a REAL hyd shop could cut that end off and get out a torch and flux covered brass rod and make it work.
PS.. if they could make up hoses, then they HAD to have some sort of compatible ends. I recall reading that they could make up hoses.. correct?
Correct, and like you thought they primarily make hoses. I think they only bend tubing with flares or connectors already in place.
/ How To Repair Bent Lines? #18
Hose shop.. Understandable.
I wouldn't expect Napa to make a brazed line, only a hose.. But a real hyd fan shop, I'd expect to be able to make something.
That clears it up.
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
2022 SANY SY26U EXCAVATOR (A63276)
2022 SANY SY26U...
2023 Kubota RTV-XG850 Sidekick (A66408)
2023 Kubota...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
40in. Skid Steer Tree Spade (A65640)
40in. Skid Steer...
