DJP
MY power steering box get low on fluid after about 20 minutes of cutting. I can refill the power fluid box and everything is good, front wheel turn perfectly, than 20 minutes later it become hard to turn and I have to turn the steering wheel around and around to just turn the tires a little. The power fluid box is out again. I see a little fluid drop on the motor below the power steering fluid box. What could be below the power steering box that may be making the fluid box loose fluid. I see one line comes down and go to the cup or box at the bottom of the steering Wheel pole. Another bigger line comes down and connect to side of the motor. Do this tractor have a power steering pump that may be leaking, if where is it? And it not heavy leaking while the tractor sitting still, maybe as I am driving or turning the tractor. Mahindra 45, Two wheel drive.
