First Tractor Implement...Build.
/ First Tractor Implement...Build. #1
BigBoyToys
Gold Member
MA
Kubota B3030
Well I really needed a landscape rake and didn't feel like dropping a grand or more into one. I had 40 yards of loam to move and spread out, with another 40 being delivered today. I knew it would be a necessity! After looking at a few builds here and pictures from different manufactures online...I came up with my design. Fortunately I had a nice piece of 5/16" angle left over from a racking system from work. It was 5' 9" long and was close enough to the 6' rake I was looking to build. I had enough 3/16" x 2 1/2" tubing so all I needed to buy were the tines, cat 1 hitch pins and a bunch of bolts. AG Supply had the best prices on the tines so I ended up buying almost everything I needed from them. Got the bolts from the local Tractor Supply. The drilling took the most time followed by the metal cutting. Got to use it this past weekend and was VERY happy with the results. The only problem is I didn't make the arms for the guide wheels long enough. I had a piece of 1/4" x 1 1/2" tubing hanging around which I cut in half knowing it would be short, but figured I could take care of that later as they just bolt on. It would be "good enough" to use for now pulling the rake forward. Other than that it worked like a champ.
Thanks to everyone here that posted their rake builds.
This site is GREAT!!! :thumbsup:
Here's a few pictures of the build...
/ First Tractor Implement...Build. #2
Dang! I am impressed. You are a skilled builder.:thumbsup:
Thanks...I don't know about that, I think I'm a better "COPIER"!!! :laughing:
/ First Tractor Implement...Build. #4
Well after buying all the tines and other materials, how much did you save? How about if you figured in new cost for all the materials that you used that were just hanging around (if you had to buy the whole lot) and include some amount for your labor, welding materials, drill bits and electricity? Was the savings that great. I contemplated building some things but the cost of materials alone was usually more than I could buy the completed product for.
By the way, in 2010 when I bought my LS, I also got a 6 foot landscape rake for $500 out the door. I suppose inflation has gotten to them in 6 years to double the cost if they are now a grand.
Well the tines were $3 ea and I bought 36 so there's $108. Shipping was free though my work account. The other materials, bolts and cat 1 mounts were around $60. New tubing and misc stock would have been somewhere around $50. So all said and done I would probably be looking at around $220 dollars. Sanding discs, welding wire and gas...call it $250. Sure my time is worth something, but **** it's better than watching the "Voice" with my wife!!!
You could find a decent 6' rake for around $6-700 but it was another $2-300 for the guide wheels. That's the $1K I thew out there.
Besides I like building stuff.
/ First Tractor Implement...Build. #6
Good looking rake, looks very sturdy. , did you make the guide wheel forks or buy them, I need to make a set of wheels for my rake.
/ First Tractor Implement...Build. #7
It is not just the money saved it is the joy and pride of building it yourself, as well as the acquisition and continual honing of his skills. Builders are more well rounded people that can do more and more as their confidence and skills continue to build thru the act of building.
That is my story and I am sticking to it.:)
/ First Tractor Implement...Build. #8
I'll second that!
If you ask me how much I saved by building it myself, my reply is how much do fishermen or hunters save on their meat and fish versus buying it at a store? Its about fun! For me its not about saving money, its about the challenge and reward of saying hey, I built that myself.
/ First Tractor Implement...Build. #9
X3! Well done.
Can you update later on the durability? I'm thinking about adding wheels to my rake. The way you did it would be straightforward and elegant. I'm wondering about the forces thoes arms will take when the tines catch a root or something and force the rake towards the ground. There's a lot of leverage on thoes arm joints. Definitely not a critique I am hoping that it works well.
I made them. Pretty basic setup. Three pieces of steel and a 3/4" rod. I just cut the sides at 45* and squared off the edge to be flush with the top piece. Drilled a 3/4" hole for the rod and welded it in place. I bought the tires at Tractor Supply. They're the airless ones. I ran short on some steel pipe so I used PVC pipe for my spacers. Cut a few 1" and a 1/2" to adjust the height. They work great and I think they'll be permanent! There's a hole drilled at the top of the rod with a "hitch pin" to keep it in place when the rake is lifted. I found the trick is to adjust the top link to get the rake to sit fairly level when it's "running".
/ First Tractor Implement...Build. #11
Where did you purchase the tines?
Nice...darn nice work!!!
X3! Well done.
Sure...The area it's being used in is pretty open and it's really just pulling rocks out before the loam is spread. It's pulled some 5-6" diameter rocks out and is fine. After that it's just leveling out 3-4" of loam, so nothing really stressful.
/ First Tractor Implement...Build. #14
Nice design, nice fabrication and nice paint job. And best of all, no "if I had to build it again ..." comments! Good work.
/ First Tractor Implement...Build. #15
. Sure my time is worth something, but **** it's better than watching the "Voice" with my wife!!!.
If I had to watch that show or any other reality show with my wife, I would be trying to build a tractor complete with implements. Luckily my wife hates all those reality shows so there wont be one on in my house ever.
Nice rake by the way. When I bought all my tractors and equipment, I was working 8 weeks on@12 hours per day overseas and 3 weeks off so my off time was more valuable than money to me. Now that I have nothing but time, I have nothing to build, darn it.
I do volunteer my time and materials to my neighbors to keep their stuff fixed up though.
Builders are more well rounded people that can do more and more as their confidence and skills continue to build thru the act of building.:)
Very true. I first started welding when I decided to build a Jeep Wrangler with my son to teach him how to work on vehicles. My feeling is "Common Sense" is something that's developed using your hands and brain to solve problems...which IMHO is lacking in our "Millennials". :( ...too much social media crap! He learned a lot and had a new found appreciation for his dad.
This past weekend my brother-in-law called and told me his truck frame was cracked. He wanted to know if I could look at it and see if it could be repaired. It's a second vehicle for him and he couldn't afford to buy another. Long story short...we repaired it for next to nothing. A flat fish plate capped with some angle...good as new. Oh yea...and the tractor was a big help getting the bed on and off!
So there may be projects where you might not save a lot and do it for the fun of it, but others where you can save BIG! :thumbsup:
/ First Tractor Implement...Build. #17
Nice build. Let us know of the long term durability of those tines. Have been kicking around the idea of building an 8' rake, as they dont seem to come up very often in the used market.
2020 CATERPILLAR 262D3 SKID STEER (A64279)
2020 CATERPILLAR...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
7' ROTARY MOWER (A63291)
7' ROTARY MOWER...
2022 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
