which brand quick connects for winch installation?
/ which brand quick connects for winch installation? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've two Badlands 2500lb winches and multiple vehicles on which to use them.
So far I've just been using jumper cables to hook them up.
I want to get some quick-connects for 6AWG wires so I can mount the quick-connects on my tractors and trucks, put quick connects on the winch then have an easier plug and play experience.
But looking at pairs of quick connects they run in price from $4 to $20 pair and I can't tell the good from the bad.
Does anyone have any recommended brands to get or avoid?
/ which brand quick connects for winch installation? #2
I use these connectors. I have them mounted on my tractor and truck.
On the tractor I use it to power a winch and on my diesel tank pump for quick fuel refills.
On the truck I have a connector on front for easy plug in of jumper cables so I don't have to pop the hood. I could also plug in a winch if I decide I need one on the front and another on the rear for my rear hitch mounted 500# lift.
Whichever ones you get stay with the same color. The red and gray plugs are not interchangeable with each other.
Amazon.com: Driver Battery Quick Connect Plug Kit from Driver Recovery Products: Automotive
Amazon.com: Battery Quick Connector Kit 175A 2AWG Plug Connect Disconnect Winch Trailer Gray: Automotive
Thanks for the links.
$12 on ebay, $19 on Amazon
$28 to $30 on ebay, $22 Amazon
I was looking at a 5 pair pack of the small ones made by X Haeibi for $44 on eBay, $39 on Amazon, wish they had the little caps.
There are cheaper ones but if you've used the X Haeibi and like them that seems like a TBN recommendation.
/ which brand quick connects for winch installation? #4
Don't know if I'd consider it a TBN recommendation but is a TBN member recommendation. I've used them for many years. Bought some at the sites I posted, some at flea markets, car show flea markets, no name connectors etc. I found the gray fits the gray and red fits red connectors. I don't crimp the connector but do solder the wires into the connector and let cool before inserting in the plastic housing. I have also unsoldered and reused connectors. they are easy to remove with a small screwdriver.
I also bought 4ga rolls of wire below.
Amazon.com: Pyramid RPB425 Ground Wire 4-Gauge, 25 Feet, Flexible, OFC Cable Wire (Black): Car Electronics
Amazon.com: Pyramid RPR425 4 Gauge Power Wire 25 feet OFC (Clear Red): Car Electronics
/ which brand quick connects for winch installation? #5
I use battery quick connects all the time. Have been making purchases from this vendor without issue, all good products, nothing Chinese unless indicated. worth a look.
McMaster-Carr
/ which brand quick connects for winch installation? #6
Perhaps the best brand in terms of quality for these connectors is Anderson Power. "Anderson" is often used as a generic name for this style of power connector regardless of the actual manufacturer. I've used one pair of X-H on a 3500 lb winch and never had any problem with them either.
/ which brand quick connects for winch installation? #7
I also use Anderson connectors, they came with the winch and I bought more.
/ which brand quick connects for winch installation? #8
I have a winch on my truck, Jeep and tractor, along with high amperage inverters and 1 gauge jumper cables and use these connectors on them all. Plus I believe they are compatible with Anderson brand connectors, which not all are. I also replaced similar quick connects I had as these have a higher build quality than the others I had.
Use the largest diameter wire appropriate for the task to minimize voltage drop. I use 0 gauge to 4 gauge- depending. On the tractor I have 1 gauge (or maybe 0 gauge) running from the battery back to the 3PH area and terminated with these connectors.
I would email the vendor and verify Anderson compatibility.
Battery Quick Connect Wire Harness Plug Disconnect Winch Trailer Connector 175A | eBay
/ which brand quick connects for winch installation? #9
For sure those Anderson are great.
Electric fork lifts use them for battery connection and charging
Tow trucks use them for booster cables,
My tractor and truck are equipped for boosting that way as are my cables.
My winch is set up with anderson as well.
To best of my knowledge the clones are compatible with anderson as well.
/ which brand quick connects for winch installation? #10
Anderson is the only way to go. Outstanding quality.
/ which brand quick connects for winch installation? #11
I love Anderson power poles in the 15-45@ range for general usage. Have a couple 75@ ones for RV battery disconnects.
Haven't used bigger ones, but wouldn't hesitate to use Andersons there too.
/ which brand quick connects for winch installation? #12
I also run Anderson connectors. My old duramax had one on back for jumpers. Lasted 10 years and then I put a salter on back and finally ate it away from salting heavy . Great quality I say. Will be putting them on my new plow truck
Well I bought the connectors and now realize I might need a better crimper.
What do you all use for crimpers for 6 gauge and up?
/ which brand quick connects for winch installation? #14
I use these types and have crimped many 00 - 6 gauge lugs. I crimp 8 gauge and larger and solder 10 gauge and smaller. The 10 ton hydraulic crimper is barely adequate in my hands and if I had it to do again would purchase a more powerful unit.
Forney 57637 Lug Crimping Tool - Battery Terminal - Amazon.com
TMS(R) 1 Ton Hydraulic Wire Battery Cable Lug Terminal Crimper Crimping Tool 9 Dies - - Amazon.com
Heavy Duty Lug Crimper - Ancor
DooLittle XTM-8418 Trailer (A66285)
DooLittle XTM-8418...
MOWER MAX SLOPE MOWER (A63276)
MOWER MAX SLOPE...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
Forklift Man Lift Safety Cage (A66408)
Forklift Man Lift...
