JD 301 Industrial
/ JD 301 Industrial #1
MDCII
Hudson valley NY
Husqvarna gt48xls
So I have a 1971 301 (3cyl gas) with FEL that I purchased a few months ago. Tractor runs pretty good but had a bogging issue and charging issue. I know the previous owner and know that it had been sitting for quite a while so I tuned it all up fixed the charging issue (voltage regulator) and had the carburetor rebuilt..... Again the tractor runs and idles very well except for the higher gears. From gears 1-5/6 it takes off pretty smooth and easy under power. However it 7/8 particularly it just wants to stall. Boggs way down and doesn't want go at all. I would say it gets progressively worse through the gears in general but I can get it moving in all of the others. Any suggestions from some of you experts would be great! After rebuilding the carb and setting the timing I'm not sure what else it could be?
Thanks a lot
Marcel
/ JD 301 Industrial #2
The way I read this you are stalling in 7-8 from a stand still?
/ JD 301 Industrial #3
You might consider installing electronic ign in lieu of points/cond.
/ JD 301 Industrial
Yes exactly. It's as if the tractor just doesn't have the power to get up and go on the higher gears. Very strange considering in all of the low speeds it's seems to run alright. I guess I'm also assuming that it runs as it should in those gears. This is the first full size tractor I have owned. But being a relatively heavy 3 cylinder I would have to imagine that in those low gears everything is right.
/ JD 301 Industrial #5
Does it seem like it's missing? Could be an ignition energy problem where the breakdown voltage is too high at higher air charges/loads. Sounds like you already changed plugs? Might try a coil. Serviced the points recently?
/ JD 301 Industrial
I replaced all ignition parts including the coil definitely not a miss type of problem. This why I have know idea where else to go lol. It's making me crazy!
/ JD 301 Industrial
The fuel is new, it had under a gallon when I bought it I put about 13 gallons brand-new gas in it
/ JD 301 Industrial #9
Did you by chance drain that gallon out? A gallon of bad fuel will ruin the new.
/ JD 301 Industrial
No that I did not do. You think that's what Happened? Bad fuel causing the engine to under perform/ loose power?
/ JD 301 Industrial #11
Hi Marcel,
Does the original owner think that the tractor has developed this problem or has the tractor been like that since new? Can you ask someone who has experience with these tractors to test drive it to see if it is acting normally? It is extremely rare that I ever use the top range on my old International but when I do use it there is a certain amount of lugging the motor to get going i.e. don't try and start up hill in eighth gear. Do you get the motor revving pretty good before letting the clutch out?
/ JD 301 Industrial
Hi Marcel,
Thank you very much for the response. I will ask him later on. I do rev it pretty good but never to the point where I I guess I'm really on it and say popping the clutch type of deal, maybe that's what is required? A more aggressive start? Because truly other than than the tractor seems to me to run well.
2019 KOHLER 38RCL Generator DISCONNECT ATS 38KW 315 HORS (A66734)
2019 KOHLER 38RCL...
2013 Ford Transit Connect Cargo Van (A66736)
2013 Ford Transit...
PORTA POTTY (A67714)
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
3142 (A63117)
3142 (A63117)
2014 Ram Pro Master 2500 Cargo Van (A66736)
2014 Ram Pro...
