Grease Question... again ;)
/ Grease Question... again ;) #1
TWD
Gold Member
Sierra Nevada Mountains - CA
Kubota M59
I've got two cases of Amsoil grease.
The "Off-Road" grease I know I use for the FEL, BH, etc...
But is the other grease for the front axle or do I have it for something else?
(Sorry! I've been ill for 2 years and haven't used the tractor really until now, and it's time to get her lubed up again!)
/ Grease Question... again ;) #2
Glad your feeling better.
Looks like the same grease just packaged differently.
Both have the same classification.
/ Grease Question... again ;) #3
They both appear to be good grease to me. The "off road" has Moly in it, which some manufactures specify for pins and bushings. It also makes it much harder to get the black moly off of your clothing. :) I would not be afraid to use either one for any use on your tractor. You will probably get a million different answers.
/ Grease Question... again ;) #4
Frequent greasing with the wrong grease is better than occasional greasing with the right grease...
/ Grease Question... again ;) #5
Molybdenum disulfide in grease forms a boundary layer on the surface of the metals and is intended for heavy loading on slow turning surfaces. It would be beneficial to keep it out of rolling bearing elements. Great for ball joints and pivot pins. Not so great for a ball bearing, save the polyurea for that.
Here is a very informative site involving lubrication and machinery maintenance.
Greases - Resources And Advice
/ Grease Question... again ;) #6
Great info, thanks for sharing
/ Grease Question... again ;) #7
Subscribed.
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
RoGator RG1300C (A63688)
RoGator RG1300C...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
John Deere 4300 32HP Front Loader Utility Tractor (A61572)
John Deere 4300...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
