A few simple mods.
/ A few simple mods. #21
Don't want to take over the thread but since this thread inspired the mod I figured I'd post it here. Unlike Billrog's, my parking break lever must be pulled up not pushed down. But like Billrog's the lever is way down low and directly above the brake pedals (on the left for my HST model MX4800). It is spring loaded and automatically disengages. However, because of the position you have to crunch over and try to simultaneously lift the lever and push hard on the brakes. The body mechanics of this make forcefully pressing on the brakes difficult.
So instead of a rod I used 3/16" braided stainless steel cable routed straight through the dash to a knob that can be easily pulled from the normal operators position. The only permanent change is a 1/4" hole drilled in the dash for a plastic grommet type thing. I routed the cable trough some old pressure washer tube to prevent the braided cable from rubbing on and wires in the dash. And ferrule and a stop to hold it all together and some heat shrink on the bottom connection to prevent the cable end from poking the sh**t out of me. The knob I found at Lowes. The whole set-up is pretensioned with the lever spring so it won't rattle around.
That is pretty cool Luke. One of the annoying little things on the L3400 I had was similar to your brake modification. The one on the L3400 was worse. it is right down at floor level and you had to double over to reach it and as you say at the same time try to put pressure on the brake pedal. It was somewhat unhandy. it looks like you put some thought into making things quite a bit handier. :thumbsup:
/ A few simple mods. #22
Ya thanks. Has made me much more likely to set the danged break when needed and thus probably safer. And I'm not putting unnecessary wear on the breaks. The good strobe and relay I installed are key.
County Line 4' 3-Pt Rotary Mower (A66408)
County Line 4'...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2022 EZ-GO ELITE...
2008 TRITON TRAILER WACKER MGT2S GENERATOR (A65643)
2008 TRITON...
2014 MACK GRANITE (A65643)
2014 MACK GRANITE...
24ft. Folding Harrow (A65640)
24ft. Folding...
