Paving my driveway
   / Paving my driveway #11
I have not looked at paving. A friend several years ago tried to get quotes for a couple thousand feet and was told they won't move equipment for something that small. Most driveways in FL and GA are concrete I assume for that reason.
   / Paving my driveway #13
Looks good BUT there seems to be a lot of loose gravel on top. Perhaps the asphalt wasn't as hot as it should have been. I sure hope it holds up for you. Plan to do some surface coating at least every 2 years to keep it water proof and help prevent cracking.
There is no loose gravel on top. I had it sealed when they finished compressing it. I also will have it "sealed and top coated" on a regular schedule.
   / Paving my driveway #15
Nice looking blacktop job. You will love it.
I noticed the edges have a 3-4" drop off. Do you plan on putting dirt or something else to get rid of the bump?
The reason I ask is around these parts many concrete driveways of sidewalks are put in and the edges are left 4" higher than the lawn. It makes a real ankle twister and an all around pain in the butt.
Yes sir, I still have a lot of work to do on the overall job. One side still has some of the old drive that I will remove and then I will dress it up along the edges and re-seed it.
Then comes the paint job on the gate and fence.
   / Paving my driveway #17
LOL, recall in my first home the city was doing paving repairs and I boldly asked the foreman if they had left over asphalt would they like to save clean up work by dumping in my driveway.
Cost me $25. 'donation' for their coffee break.
And they roller compacted as well.
Called being right time right place, I guess.
   / Paving my driveway #18
Looks great. Hope the guy doesn't damage it when he comes to pick up that dumpster.
   / Paving my driveway #19
Thats what I was thinking. Going to need to make the transition from dirt to asphalt even for that dumpster.
I solved the problem with the dumpster, I moved it across the street to my buddys gravel drive with his permission and the right to use it. That will work out great for both of us.
New Wolverine Mini Skidloader Post Hole Digger (A50775)
New Wolverine Mini...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
2018 Ford Transit 350HD Handicapped Van (A55788)
2018 Ford Transit...
TRAILER AXLE (A54756)
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
