Back Saver.
/ Back Saver. #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
I herniated a disc in my back in October 2015. My back is not capable of taking abuse any more.
I look at the thousands of tons of rocks moved and made retaining walls, The Thousands of yards of material landscaped into pastures, roads and ponds, I can't do that now.
I've lost my knack with operating my excavator. A few years ago I was putting +500 hours a year on it working the farm while mostly unemployed. I amazed myself what I could do with the machine. No more. I cam operate it well still, but as far as using the bucket and thumb as if it were a hand, no longer am I that skillful.
If I'm careful I can still dead lift over 100 lbs, but I can not work like I used to be able. I am glad I got this far and the place is established but Now I need to figure ways to make life easier.
Like how do you take a few minutes to go into the woods to haul out 1/6 cord of wood? Or how to move buckets of manure from stalls without lifting heavy buckets. Take a 60 gallon tank of water out to the pasture?
This ought o be the ticket.
The carryall's internal dimensions are 57-1/2 wide x 33 deep x 27 high, just under 30 cubic feet. I can use a ramp to load something real heavy like my generator or just hump it 6" to load. This should prove handy. It will carry 6 bales of hay. My wife often uses the RTV, when I could be using it so I have something little for chores also.
/ Back Saver. #2
Looks good Mike, sorry to hear about the back issues. Carry All looks like another handy addition. Also nice job on your curl cylinder project on the Max.
/ Back Saver. #3
I have had one for years, you will find good use for it I am sure. Looks good. Ed
/ Back Saver. #4
Looks very handy to me.
/ Back Saver.
Well done, Sir.
For those who are DIY challenged and deep of pocket,
there is the Big Tool Rack.
I give this guy credit, being able to market this successfully. I looked into marketing my better quick hitch, and only those with deep pockets could afford what I would have to ask for it.
/ Back Saver. #7
I have the same carryall, probably the best money I've spent on a tool thus far. Mine stays on the tractor unless another implement is needed. Thinking about adding some PVC tubes for shovels and rakes as well as chainsaw holsters.
/ Back Saver.
Good ideas!
I had a bit of welding done on my carryall frame so that the angles are fully welded as well as a small pair of gussets added, just in case I carry more than 500 lbs. Still a good buy from Tractor supply, as the raw steel stock to make your own would cost more.
2005 John Deere 7420 (A60462)
2005 John Deere...
2020 BOBCAT T770 SKID STEER (A62129)
2020 BOBCAT T770...
2018 CATERPILLAR 236D SKID STEER (A62129)
2018 CATERPILLAR...
CATERPILLAR 140 AWD MOTORGRADER (A63276)
CATERPILLAR 140...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A61165)
2021 Ford...
2014 Kubota RTV X900 4x4 Diesel Utility Cart (A61567)
2014 Kubota RTV...
